Looking for UN-glued teak veneer roll.
Spedley
Postby Spedley » Sat Nov 26, 2016 10:02 pm
I've scoured the usual sources but all I can find is pre-glued iron on veneer.
I'm looking for 50 metres of 50 mm wide teak veneer without glue. I wan't it to cover a dining table to match an existing one and it may have hot plates etc placed on it. Also, I find the hot-melt glue awkward to use when you have multiple strips together.
I can only find what Google has to offer which means I'm missing out on many suppliers which don't have websites or just aren't indexed. I also need it within a couple of weeks - so I can finish by Christmas.
Can anyone point me in the right direction?
Thanks!
Spedley
Re: Looking for UN-glued teak veneer roll.
Postby Spedley » Thu Dec 29, 2016 4:36 pm
Gave up in the end and bought an 8'x4' sheet of paper backed veneer. Glued it using the iron on PVA method giving great results. A bit expensive though.
I do understand now why it is hard to get unglued veneer, without some kind of backing very thin veneer tends to split and fall apart.
Postby promhandicam » Mon Jan 02, 2017 8:05 pm
Where did you source it from in the end?
Postby woodsmith » Tue Jan 03, 2017 9:31 am
Sorry I didn't see your original post, Ostermanns would almost certainly been able to supply you with the veneer you wanted.
