Walnut and maple picture frame - clear finish?
Mike_5
Postby Mike_5 » Tue Feb 21, 2017 8:05 am
I'm looking to finish off my picture frame in a clear coat. I've seen on some clips that people talk about a clear coat lacquer, but all I seem to find are ones for cars. Do I just use a clear coat varnish?
bloonose
Re: Walnut and maple picture frame - clear finish?
Postby bloonose » Tue Feb 21, 2017 10:51 am
Use some Osmo polyx oil, a sample pot will be more than enough, will not make the maple yellow either ;) plus very easy to apply.
Mike_5
Postby Mike_5 » Tue Feb 21, 2017 12:28 pm
Thanks, I've had a look and there are a few options, but the Osmo Polyx oil natural transparent- raw, seems the appropriate definition of what I'm looking for. I would assume this suits under what you recommended? Never really finished off any woodwork besides in paint before! So this is all new territory to me.
Mike_5
Postby Mike_5 » Tue Feb 21, 2017 1:01 pm
Actually, just going to pop to local supplier as they have Oslo Polyx Hardwax Oil clear satin Matt, description sounds good. I'll check this thread again before I open the product in case ;)
Postby promhandicam » Tue Feb 21, 2017 8:38 pm
The above should be fine - I use it on virtually everything except for external woodwork!
bloonose
Postby bloonose » Wed Feb 22, 2017 10:49 am
Application of it, use a little as possible using lint free cloth wipe on till absorbed in direction of grain. When dry do the same again until several coats have built up to lustre you require. If you do put too much one wipe off excess with clean cloth, you'll soon get the hang of it, works great. ;)
Mike_5
Postby Mike_5 » Thu Feb 23, 2017 10:35 am
All finished, wife and I are quite happy with my first picture frame.
Thanks for all the advice!
