Adjustable shelf system
ruffdog64
Post by ruffdog64 » Wed Feb 07, 2018 2:56 pm
What does everyone use for adjustable shelving in units?
Re: Adjustable shelf system
Post by Jonathan » Thu Feb 08, 2018 7:15 pm
I use 3mm shelf supports from Hafele, and tonk type system from ironmungery direct.
Oakfield
Post by Oakfield » Thu Feb 08, 2018 9:07 pm
I used to use the metal sleeves with metal shelf pin from LDLOnline. But have just moved to 5mm hafele shelf supports.
Post by promhandicam » Mon Feb 12, 2018 8:37 am
I've got a veritas shelf jig which is great for the 5mm shelf supports but I don't think it has a bush for a 3mm hole which is what I prefer using. I need to find someone with a lathe who can turn one up for me.
Post by Tomyjoiner » Mon Feb 12, 2018 10:16 pm
As above Tonk strips routed in or 3mm metal with clear plastic shelf supports from Haffele
Post by davidpidge » Tue Feb 13, 2018 9:50 pm
I use the 7.5mm sleeves with spade supports or flush bookcase strips.
