Zobo-style forstners with a pilot (which may or may not be self-drilling depending on how you want to use them) would help.
Below is a link to a piece about the Festool branded ones (which is how I came across them).
http://www.core77.com/posts/25985/Festo ... t-The-Zobo
Search found 1787 matches
- Wed Mar 16, 2016 1:51 am
- Forum: Finishing
- Topic: coloured glass splash backs
Re: coloured glass splash backs
This is where I sourced the glass paint from http://www.avko.co.uk/product-category/surface/glass/ (they recommended the second glazier and were good to deal with, the first glazier used Movac paint). I would use proper glass paint, I think it is silane modified so that glass's hydrophilic nature do...
- Mon Mar 14, 2016 11:58 pm
- Forum: Finishing
Only a one-off from me, but I used MS polymer to stick it up, including a bit which goes horizontally under an overhang and it hasn't dropped yet in erm years. Have to be v careful with silicone as the acetic acid in the non-neutral cure stuff will attack paint.
- Mon Mar 14, 2016 9:07 pm
- Forum: Finishing
This was 4mm. It may have been some sort of spectrum oddity, as the paint both glaziers sourced (from different companies) was right against the NCS sample card, and if you put the sample card behind the glass it looked fine, but on application it just washed out. It was miles off, not just a bit. W...
- Mon Mar 14, 2016 10:54 am
- Forum: Finishing
Make sure you use Low Iron if a light colour, it'll change the paint colour with the pigments in the glass. Even low iron glass changes the colour. It took 3 tries with 2 companies to get our splashbacks to match the yellow laminate, even though the paint was to the same NCS colour ref and was perf...
- Sun Feb 21, 2016 6:32 pm
- Forum: Woodworking
- Topic: 'Solvent Free' contact adhesive
Re: 'Solvent Free' contact adhesive
F+B are generally renowned for being carp paint, I don't think the solvent versions are held in any higher regard than their waterbased stuff.
- Tue Feb 02, 2016 8:15 pm
- Topic: Beginner Desk Joinery
Re: Beginner Desk Joinery
Cost of birch ply is true, I don't think the ply would delaminate as long as you pilot drilled.
- Mon Feb 01, 2016 11:58 pm
Even easier would be screws straight down through the top into the legs. If you were to space, mark and drill the screws accurately, you could either use some smart looking screws (for eg look at spax stainless decking and timber cladding screws, or their washer head screws, etc) or you could counte...
- Mon Feb 01, 2016 9:03 pm
- Forum: Power Tools and Machinery
- Topic: The very best cordless drill money can buy?
Re: The very best cordless drill money can buy?
SDS-Max would be more best for hammer drilling oak.
- Sat Jan 30, 2016 11:19 pm
- Forum: Projects
- Topic: Side-gates
Re: Side-gates
Thanks for everyone's nice comments. Unlike usual, I can't take much personal credit for much of it apart from speccing and paying for it, and the gates. I did strip the paint off the stonework which was hideous (at the same time I was stripping some cornices inside, I never want to see Peelaway aga...
- Sat Jan 30, 2016 11:16 pm
- Forum: Projects
- Topic: Side-gates
Re: Side-gates
oops duplicate
- Sat Jan 30, 2016 8:51 am
- Forum: Projects
- Topic: Side-gates
Re: Side-gates
Should be back - Photobucket has been borked too over the last couple of days.
- Wed Jan 27, 2016 6:59 pm
- Forum: Projects
- Topic: Side-gates
Re: Side-gates
Fecking Microsoft have crippled Onedrive apparently by changing it so it no longer allocates a static url to a document.
Will move them to imageshack or whatever I used to use.
- Tue Jan 26, 2016 10:55 pm
- Forum: Projects
- Topic: Side-gates
Re: Side-gates
Got there at last a few weeks ago http://i873.photobucket.com/albums/ab300/jakeh6/WP_20160109_15_20_26_Pro_zpsog9bqumj.jpg http://i873.photobucket.com/albums/ab300/jakeh6/WP_20160109_15_20_40_Pro_zpsbhmptmom.jpg http://i873.photobucket.com/albums/ab300/jakeh6/WP_20160109_15_20_46_Pro_zpsvbfiyqjz.jpg...
- Thu Jan 14, 2016 9:58 pm
- Topic: steam bending diy
Re: steam bending diy
I hasve never used it for steaming but soil pipe comes in ABS (most pushfit systems) and PVC (more solvent weldable). PVC has a much higher melting temperature - like above 200c rather than 100c.
- Mon Sep 21, 2015 10:04 pm
- Forum: Projects
- Topic: Side-gates
Re: Side-gates
Hmm food for thought cheers Mark, no not even started yet on the gates themselves.
- Fri Sep 18, 2015 11:20 pm
- Forum: Projects
- Topic: Side-gates
Re: Side-gates
Alright bollox I'll just do what I want. :p
- Fri Sep 11, 2015 9:58 pm
- Topic: what size blade?
Re: what size blade?
Blades for mitre saws should have a negative hook angle (teeth lean backwards, not forwards into the cut). TS blades should have positive hook angles.
Wealden do decent blades or Cutting Solutions who at least used to be on here.
- Fri Sep 11, 2015 9:47 pm
- Forum: Projects
- Topic: Side-gates
Side-gates
As part of the endless renovation project, I get to do some woodwork hoorah. Some side-gates between my semi (no sniggering at the back) and my next-door neighbours semi (no sniggering at the back). One of the last parts of big push to do our frontage (new roof, tick, repointing, tick, strip back an...
- Fri Sep 11, 2015 8:06 pm
Yes 4mm is not going to make any difference. But, the blades for TS and mitre saws are very different so don't mix and match.
- Thu Jul 23, 2015 8:03 pm
- Topic: Stick-on glazing tape
Re: Stick-on glazing tape
There are loads around - often not labelled as such but if you look for things which say they are both adhesives and sealants they are usually ms polymer, and looking on the ingredients usually confirms, or saying things like sets under water is a giveaway. CT100 is expensive but very reliable in my...
- Wed Jul 22, 2015 9:29 pm
- Topic: So who is looking ?
Re: So who is looking ?
I like the name, Parquet Dave, and welcome. I'm just about to start thinking about pulling the 60sqm of rather lovely reclaimed partridgewood woodblock out of my shed (where it's been waiting for a few years) for my living rooms which are just about to be plastered. I might need to pick your brains ...
- Wed Jul 22, 2015 9:24 pm
- Forum: Finishing
- Topic: Paintable silicone sealant
Re: Paintable silicone sealant
No it's just f**king ace (apart from some bathroom specific crap I bought which has gone horribly yellow, at least I could paint it I suppose) and so much better than silicone.
- Mon Jul 20, 2015 8:52 pm
- Forum: Finishing
MS polymer
- Tue Jul 14, 2015 7:57 am
MS polymer sealant is better than silicone, longer lived, ph neutral so glazing safe, and paintable to boot.
- Wed Apr 15, 2015 6:55 pm
- Topic: Kitchen Units
Re: Kitchen Units
Carcasses might be Frontline who I used, but there have been others mentioned.
- Wed Apr 01, 2015 10:49 pm
- Topic: Sash windows
Re: Sash windows
Duplex bars look rubbish, but in the absence of x-ray vision, how can you tell whether a glazing bar is a stick-on or not (assuming spacers in the unit behind the bar)? Apart from the fact that they be as elegantly slim as a single glazed proper bar (which slimlite can't match)? I don't really unde...
- Wed Apr 01, 2015 6:14 pm
Re: Sash windows
- Mon Jan 26, 2015 10:15 pm
- Topic: Anyone running a Guilliet KXT
Re: Anyone running a Guilliet KXT
MJ80 wrote:Good to know, looks ideal for my evil plans
Beats waterboarding?
- Mon Jan 26, 2015 10:02 pm
- Forum: Turning
- Topic: Anyone identify type of timber from sea defence
Re: Anyone identify type of timber from sea defence
harveythewhiterabbit wrote:What about the deep red bit of groin?
Wrong website for that fella, you need to go see the clinic.
- Tue Dec 16, 2014 11:32 pm
- Topic: Centre door knob latch.
Re: Centre door knob latch.
They just pull, bolt on the other side, nothing to do with locking.
- Tue Dec 02, 2014 8:48 pm
- Topic: A Very Long WIP
Re: A Very Long WIP
I hope you got this for not too much more than the land value!
Hats off for dedication and effort, and just plain doing things thoroughly right.
- Sun Nov 30, 2014 10:21 pm
- Forum: Projects
- Topic: Oak Balcony Guard
Re: Oak Balcony Guard
Nicely done!
(Is that fecking plastic on the inside of the dwarf wall?)
(oh and that poor lady of the statue had all her limbs brutally chopped off, is this like some warning to intruders, a modern head on a pole or something?)
- Sun Nov 30, 2014 10:19 pm
- Topic: Testing for wood preservative
Re: Testing for wood preservative
Is there a more specific specification? There are all sorts of things which will help preserve wood for a day or two, then obviously a spectrum from there up. So unless you have some more specifics the statement is almost meaningless (the ph of some urine would probably retard fungi etc for a few da...
- Fri Nov 14, 2014 11:12 pm
- Forum: Projects
- Topic: Front Door
Re: Front Door
Lovely door. The proportions of the opening you had to work to are a bit odd for a single door.
- Wed Nov 05, 2014 11:28 pm
- Topic: Stick on glazing beads and bars
Re: Stick on glazing beads and bars
It will be silane primer and 3M VHB.
- Tue Nov 04, 2014 10:35 pm
Well the longer you can't see my TV but I can see mine the better.
But tomorrow is OK if you want to deliver frames then and start fixing on Thursday when the glass is due.
- Tue Nov 04, 2014 9:31 pm
Oh right I thought you mean the beads, not the fake inside bar. Yes some 6" nails should fix them to the glass nicely.
ps glass delivery on Thursday
- Mon Nov 03, 2014 11:43 pm
I happen to think that in this instance at least beads and bars can be differentiated. I'm terribly presumptive or do I mean prescriptive. I think the inside beads can be fixed with a 20g air pinner which might be present on site. And the fake-e-ola bars might nonetheless need some decent stuff rath...
- Fri Oct 31, 2014 11:24 pm
- Forum: Projects
- Topic: Conservatory Wardrobes - Finished.
Re: Conservatory Wardrobes.
The epoxy resin and bulking agent for just those two laminates cost me something like £40- £45, roughly £15 a litre (two mixings of about 1.2- 1.5 litres each), including filler and catalyst ... I don't recall the exact figure now, but the relatively stress free mix, glue application, and first tim...
