Search found 419 matches
by davidpidge
Sun Dec 13, 2020 6:51 pm
Forum: Projects
Topic: Caravan/chest.
Re: Caravan/chest.
Nicely done. 👌
by davidpidge
Mon Dec 07, 2020 11:49 am
Forum: Power Tools and Machinery
Topic: Sander recommendations
Re: Sander recommendations
A mains sander will probably have more oomph but more important is the speed and orbit pattern. Some sanders have smaller pattern of say 2mm for fine work and some have a 5mm pattern for quicker, more aggressive sanding. Look at a good budget 150mm like the metabo sxe 450. Or for seriously quick rem...
by davidpidge
Mon Dec 07, 2020 8:05 am
Forum: Projects
Topic: PHP Errors
Re: PHP Errors
Because what does that even mean?
by davidpidge
Fri Nov 27, 2020 9:58 pm
Forum: Wanted
Topic: Wide belt sander, spindle moulder
I'm going to start contacting dealers but wondered if anyone has a 950mm wide belt sander going? We also need a spindle with sliding table and power feed (power feed not so important as we can get one).
by davidpidge
Fri Oct 02, 2020 8:07 pm
Forum: Woodworking
Topic: Help me determine this wood grain
Re: Help me determine this wood grain
Post a photo of it sanded. Could be ash or oak but it's been stained so who knows?
by davidpidge
Wed Sep 30, 2020 8:16 pm
Topic: Casadei router
Re: Casadei router
Try calling TWS machinery. They're an SCM/casadei dealer and may have an old manual. Worth a shot?
by davidpidge
Wed Sep 30, 2020 8:15 pm
Forum: Woodworking
Topic: What type of plywood is this??
Re: What type of plywood is this??
Is the lighter ply softer and lighter in weight than the birch?
by davidpidge
Wed Sep 16, 2020 7:00 pm
Forum: Woodworking
Topic: Woodworking With Children
Re: Woodworking With Children
Could start on the free version of sketchup and it'd be a good skill for him to have. Some router work would be ok wouldn't it? Get him set up and do some small round over or groove work. Using a table is pretty safe with feather boards and push sticks. Learning how spinny sharp things behave is imp...
by davidpidge
Thu Sep 10, 2020 8:50 pm
Forum: Woodworking
Topic: Draw runners?
Re: Draw runners?
Stick with blum movento. Best there is and smooth closing action.
by davidpidge
Mon Aug 31, 2020 8:00 pm
Forum: Woodworking
Topic: Floating shelf bracket for books?
Re: Floating shelf bracket for books?
Threaded bar, resin. Easiest, strongest option by far.
by davidpidge
Wed Aug 26, 2020 9:53 pm
Forum: For Sale
Topic: Festool MFK 700 EQ-set 240volt price reduced - SOLD
Re: Festool MFK 700 EQ-set 240volt price reduced
Can you post a photo of the label with the T-nr number etc. I might be interested as I was about to buy one anyway.
by davidpidge
Sun Aug 09, 2020 11:04 am
Forum: Woodworking
Topic: Bench project: where to get timber?
Re: Bench project: where to get timber?
Contact your closest cabinet maker/joiner and ask them to supply you some prepared timber to the sizes you need.
I'd be happy to supply someone if they gave me a cutting list. Might take a few weeks though!
by davidpidge
Fri Jul 31, 2020 6:47 am
Forum: For Sale
Topic: quality router table
Re: quality router table
Location and photos might help
by davidpidge
Fri Jul 31, 2020 6:44 am
Forum: Woodworking
Topic: Decent internal door handles
Re: Decent internal door handles
Sds London
by davidpidge
Fri Jul 17, 2020 9:01 pm
Forum: Woodworking
Topic: A job for knockdown fittings ?
Re: A job for knockdown fittings ?
Middle cab pulls out on heavy duty castors for access to water tank and all the plumbing.
by davidpidge
Thu Jul 02, 2020 8:16 pm
Topic: Just starting out and need table saw advice
Re: Just starting out and need table saw advice
If you're cutting sheet material for cupboards then even a cheap track saw can be extremely accurate. You also need less space than a table saw to cut large pieces.
I lived without a table saw for years when I started out.
by davidpidge
Mon Jun 22, 2020 4:41 pm
Topic: 4 sider extraction
Re: 4 sider extraction
I've ordered an iTech twin bag with 5000m³/h flow with a 200mm inlet so plenty and could potentially take a 2nd machine at the same time.
Nice compact machine considering the massive flow rate.
by davidpidge
Sun Jun 21, 2020 9:57 pm
Forum: Forum suggestions/comments/complaints
Topic: Forum search issues
Re: Forum search issues
Haha, cheers! I didn't think to scroll down. You're right it's underneath.
by davidpidge
Sun Jun 21, 2020 6:47 pm
Thanks for the reply. I think its going to be underpowered so I'll start looking for a replacement.
I can't find the specs anywhere online and the dealer isn't much use atm as they're mostly shut down due to covid.
by davidpidge
Sun Jun 21, 2020 4:07 pm
4 sider extraction
Hi all, Got my sintex XL coming in a couple of weeks. I got a twin bag, Felder AF 22 extractor that sucks 3100m³/h. It's a used machine from another woodworker and I could still give it back to him if it's not up to the job. So, anybody know if I should get a bigger extractor? The extractor will onl...
by davidpidge
Sun Jun 21, 2020 3:58 pm
Forum search issues
Hi, if I use the search function on click on 'my posts' I just get a page of script. Anyone else have this issue?
by davidpidge
Sat Jun 06, 2020 2:02 pm
Forum: Woodworking
Topic: 18mm or 24mm ply?
18mm or 24mm ply?
I've been asked to quote to replace some wardrobe doors with birch ply. I usually dissuade people from large birch doors as they tend to warp or twist.
Anyone notice a difference between 18mm and 24mm in terms of stability? The doors are 530mm x 1830mm so not too big.
by davidpidge
Fri May 01, 2020 9:52 am
Forum: Wanted
Topic: Combination machine
Re: Combination machine
I would ring/email a few machinery dealers if I were you. Tell them your requirements and a budget and they will tell you if they think they can find something. Sometimes they will unload a machine for cheap if they don't want it taking up space. Ebay is more expensive than dealers these days!
by davidpidge
Sat Apr 04, 2020 5:54 pm
Forum: Woodworking
Topic: Joining legs to worktop
Re: Joining legs to worktop
The benefit is all you need is a drill and table saw or chop saw with depth stop.
by davidpidge
Sat Apr 04, 2020 5:53 pm
Forum: Woodworking
Those brackets will work but obviously won't look great and you won't be able to mount the leg too near the corner.
I would use a standard knock down bracket (attached) which will mean adding an apron around 3 sides of the top.
attachment=0]d3ba246dfb4607b26bd0540b99d8eafe.jpg[/attachment]
by davidpidge
Thu Mar 26, 2020 5:51 pm
Forum: Woodworking
Topic: Basic tools?
Re: Basic tools?
Are you planing to make and finish everything with hand tools or power tools? Will you be buying timber prepared or are you hoping to do that yourself? Hard to say what tools you'll need unless you have more specific requirements. I usually design things around the tools i have rather than buying to...
by davidpidge
Thu Mar 26, 2020 1:52 pm
Forum: Finishing
Topic: Dark stain
Re: Dark stain
I'll take a look.
by davidpidge
Thu Mar 26, 2020 8:01 am
Forum: Finishing
Topic: Dark stain
Dark stain
I need to get a finish close to this....
It's on ash i believe and has quite a lot of sun damage so not worried about mimicking that. I was thinking a fiddes stain and waxoil on top?
Any advise welcome. Cheers!
by davidpidge
Thu Mar 19, 2020 8:51 pm
Forum: Woodworking
Topic: Beginner Woodworker help.
Re: Beginner Woodworker help.
Companies like timbersource will plane timber to any size you want. Or find a local cabinet maker/joiner to plane some timber for you. They'll charge you an hourly rate probably.
by davidpidge
Fri Mar 06, 2020 8:56 pm
Forum: Woodworking
Topic: Looking for suitable tool
Re: Looking for suitable tool
Router table or spindle moulder. Easy with either.
by davidpidge
Thu Feb 20, 2020 4:40 pm
Topic: Kelvin Power Tools
Re: Kelvin Power Tools
Powertool supplies always have the best festool prices. Or FFX through ebay with the ebay money off offer.
by davidpidge
Thu Feb 20, 2020 4:37 pm
Forum: Woodworking
Topic: Pocket Screw Holes
Re: Pocket Screw Holes
Put biscuits/dominoes as well as pocket screws. Put plugs in to cover them or fix a panel to cover the entire underside.
by davidpidge
Mon Feb 10, 2020 11:21 am
Topic: Manual for Sedgwick MBT needed
Re: Manual for Sedgwick MBT needed
I've always found sedgwick to be really helpful. Just call them and ask?
by davidpidge
Tue Jan 28, 2020 9:05 pm
Forum: Woodworking
Topic: Casement windows on the cheap
Re: Casement windows on the cheap
They specifically ordered lengths of domino. Why not make their own in matching timber if they've got a thicknesser and router table? Shouldn't use beech dominoes for exterior work.
by davidpidge
Thu Jan 16, 2020 12:11 pm
Forum: For Sale
Topic: Graco ultra spray gun 2 x DeWalt 18v batteries
Re: Graco ultra spray gun 2 x DeWalt 18v batteries
Check my last insta post for photo. @mr_pidgeon
by davidpidge
Wed Jan 15, 2020 10:27 am
Forum: For Sale
Graco ultra 18v spray gun for sale
Used for a year.
Pump replaced by spray direct with receipt and hasn't been used since.
£350 collected or £15 p+p
Will upload photos later but its all there including box and carry bag.
by davidpidge
Sat Jan 04, 2020 11:28 pm
Topic: ITECH 310S PLANER THICKNESSER
Re: ITECH 310S PLANER THICKNESSER
Thanks for posting the review. I recently had a go on an SCM planer with spiral block and it was incredible. You wouldn't need ear defenders using it!
by davidpidge
Tue Dec 31, 2019 11:28 pm
Forum: Woodworking
Topic: Joint suggestion
Re: Joint suggestion
This is when the Zeta p2 pays for itself!
by davidpidge
Tue Dec 31, 2019 7:52 am
Forum: Woodworking
Biscuits but clamping would be tricky.
