Search found 993 matches
by Meccarroll
Tue Apr 13, 2021 8:43 pm
Forum: Projects
Topic: Past project
Re: Past project
oldboy22, I have a very simple way of obtaining the bevels for wreathes but I would like another as a double check I have read about other ways of obtaining the bevels but they are complicated so I have to admit I am not found of them. Your method looks quite like it may be easy and quick, is there ...
by Meccarroll
Mon Apr 12, 2021 6:02 pm
Forum: Projects
Topic: Past project
Re: Past project
Looking at Plate 70 page 132, the line O-O looks to be on a slant. Is that correct (I think it is and is there by virtue of sliding the face mould) ? Sorry for the late reply Rodger I've been at work. You are correct. If you stand the wreath in an upright position as it will be when fit to the stai...
by Meccarroll
Mon Apr 12, 2021 4:07 am
Forum: Projects
Topic: Past project
Re: Past project
.... I am applying the methodology of W & A Mowat which uses the minor axis to determine the crossover points for the wreath and from that point I was going to use a series of diminishing vertical marks from where the twist starts and then finish at the point of minor axis. .... I'm misunderstandin...
by Meccarroll
Sun Apr 11, 2021 8:10 pm
Forum: Projects
Topic: Past project
Re: Past project
Meccarroll If you follow my previous advices and work the new vertical surfaces first it’s easier to hold in the vice, two parallel surfaces to grip. I was aware of that sides come first oldboy22 . If you then cut a piece of paper or thin card the thickness of the rail and long enough, you can lay ...
by Meccarroll
Sun Apr 11, 2021 9:01 am
Forum: Woodworking
Topic: Repairing an old elevated playhouse
Re: Repairing an old elevated playhouse
Photos are always good to help with this sort of question. Don't be afraid to do a proper job. The screws might be stuck which might mean you have to spend more time on the repair than you would like but that should not cloud your judgement. As you have pointed out there are children involved so eve...
by Meccarroll
Sat Apr 10, 2021 7:24 pm
Forum: Projects
Topic: Past project
Re: Past project
Here's a few photos, Mark. I can see the advantage now of a ply template. Do transfer all of the relevant markings to the template including the Tangent lines and Minor Axis as this will allow you to use the Minor Axis as a reference point when lining up and cutting the wreath. Thin ply/MDF templat...
by Meccarroll
Sat Apr 10, 2021 7:14 pm
Forum: Projects
Topic: Past project
Re: Past project
Meccarroll How’s it going ? Had a chance to have a go at it yet, I’m looking forward to seeing it . Hope you took/ take some stage photos. I have been doing the garden, tidying the garage and making an ellipse jig so not had time to take things any further. My CAD programme is quite dated and a bit...
by Meccarroll
Sat Apr 10, 2021 6:32 pm
Forum: Woodworking
Topic: Staircase upgrade ..
Re: Staircase upgrade
That looks really good Rodger, in fact Bl..dy Brilliant!
You are moving leaps and bounds now.
This is the hardest part of the handrail so moving on to the Volute and lower Wreath should prove much easier to do.
by Meccarroll
Fri Apr 09, 2021 6:25 am
Forum: Woodworking
Wow Rodger that's great to see. If you gave this project to most carpenters or joinery specialists they would run a mile and I mean the real ones not the clowns that claim to be professionals. Most good joinery shops can make stairs and do circular work but I have never personally come across any lo...
by Meccarroll
Thu Apr 08, 2021 7:20 pm
Forum: Projects
Topic: Past project
Re: Past project
It's so hard getting that twist out of the wood. Making sure that you're gradually rotating the faces. Any tips ? 1. Make a board stand on edge vertically near to the bandsaw blade so you can use it to rest the Wreath on wile you do the cuts. Round over the top edge of the board so the wreath slide...
by Meccarroll
Thu Apr 08, 2021 9:29 am
Forum: Projects
Topic: Past project
Re: Past project
Thinking on it I’ve made a cockup you should add a straight bit to both ends and reduce the easing by that amount , I don’t know why I drew it like that but I did. You don’t put a straight bit where one twist joins another twist ,but of course the easing isn’t twisted . :oops: That's what SCMS's ar...
by Meccarroll
Wed Apr 07, 2021 8:14 pm
Forum: Projects
Topic: Past project
Re: Past project
My latest Drawing of Rodgers Quarter Turn, re drawn because my Cad Programme seems to think kindly of wiping my saved files into oblivion for no reason!!! Rodger wreath.jpg Fortunately I managed to print the wreath out before it disappeared so I stand a chance of testing the results of my drawing.
by Meccarroll
Wed Apr 07, 2021 8:00 pm
Forum: Projects
Topic: Past project
Re: Past project
Thinking on it I’ve made a cockup you should add a straight bit to both ends and reduce the easing by that amount , I don’t know why I drew it like that but I did. You don’t put a straight bit where one twist joins another twist ,but of course the easing isn’t twisted . :oops: Check Mowat Page 210,...
by Meccarroll
Wed Apr 07, 2021 5:30 pm
Forum: Projects
Topic: Past project
Re: Past project
This all seems to be moving along nicely, I do hope all goes well.
by Meccarroll
Wed Apr 07, 2021 2:17 pm
Forum: Projects
Topic: Past project
Re: Past project
Here’s a different technique to draw the ellipse, this is what I used to work out the handrail in my staircase (first page), I didn’t really understand it at the time but it worked, I didn’t have as many books or as much knowledge back then. That seems to follows the same method used by Mowat Fig. ...
by Meccarroll
Wed Apr 07, 2021 5:01 am
Forum: Projects
Topic: Past project
Re: Past project
OK...I'm having one more crack at this. I revisited my drawing and although I had intended to pick up the different widths of the ellipse at either end and had done so, I'd used the wrong reference markers - which is why Oldboy thought they were parallel (they're not but marginally...hence the conf...
by Meccarroll
Tue Apr 06, 2021 6:35 pm
Forum: Projects
Topic: Past project
Re: Past project
Question: Why do you suppose the minor axis is not correctly positioned? I thought I followed the book or to be more precise where did I deviate? The end of the ellipse at Q is wider than at P so there is a deviation in the points of the ellipse. I think that may be an important point that I have o...
by Meccarroll
Tue Apr 06, 2021 6:26 pm
Forum: Projects
Topic: Past project
Re: Past project
On closer look I think I notice you don’t have the minor axis point correct, if the rectangle is supposed to be the centre line of the ellipse the radius used should be to the centre line of the ellipse, if so that makes your spring lines out. I also think something is out but not quite sure what s...
by Meccarroll
Tue Apr 06, 2021 6:21 pm
Forum: Projects
Topic: Past project
Re: Past project
PS: oldboy22, If I have missed any points you raised it's because I am now winding down for the day but appreciate your input and will look to answer then asp! In the mean time Take care.
by Meccarroll
Tue Apr 06, 2021 5:56 pm
Forum: Projects
Topic: Past project
Re: Past project
This is where I am at at the moment. I am having a bit of trouble forming the ellipse with my CAD software Rodger Drawing.jpg (1) Very good although a little busy it’s hard to pick out the the important bits, I love the way you’ve used Mowatt to develop the upper tangent but you have also used the ...
by Meccarroll
Tue Apr 06, 2021 5:06 pm
Forum: Projects
Topic: Past project
Re: Past project
by Meccarroll
Tue Apr 06, 2021 4:05 pm
Forum: Projects
Topic: Past project
Re: Past project
This is where I am at at the moment. I am having a bit of trouble forming the ellipse with my CAD software (TurboCad 4 for Mac). Because the ellipse is on an angle and the programme does not seem to like working other than horizontal or vertical. I have used it in the past to perform ellipses for wr...
by Meccarroll
Tue Apr 06, 2021 11:51 am
Forum: Projects
Topic: Past project
Re: Past project
[ The drawing for Rodgers stairs should come out similar to mine if you follow the same dimensions depending on you development process. I am working from a stretch-out which is the product of the riser and going dimensions Rodger gave to me. From the actual stair dimensions I am producing the draw...
by Meccarroll
Tue Apr 06, 2021 9:20 am
Forum: Woodworking
thatsnotafestool wrote: ↑
Tue Apr 06, 2021 8:47 am
Sorry, mark..got pulled away on other 'vital' war work.
Never mind, all in good time. ;)
by Meccarroll
Tue Apr 06, 2021 8:07 am
Forum: Woodworking
Mon Apr 05, 2021 9:10 am
I'm working on the easing today. The Asian approach comes later. :lol:
Keen to see the next stage, any updates Rodger?
by Meccarroll
Tue Apr 06, 2021 8:02 am
Forum: Projects
Topic: Past project
Re: Past project
If those first practice pieces were made 35 - 40 years ago and you made the set of stairs 15 years ago you have spent a long time learning tangent hand-railing. What was the material used to form the curve for the strings? I see a lot of this work done in ply then covered with veneer but some use s...
by Meccarroll
Tue Apr 06, 2021 5:18 am
Forum: Projects
Topic: Past project
Re: Past project
If those first practice pieces were made 35 - 40 years ago and you made the set of stairs 15 years ago you have spent a long time learning tangent hand-railing. What was the material used to form the curve for the strings? I see a lot of this work done in ply then covered with veneer but some use so...
by Meccarroll
Mon Apr 05, 2021 9:06 am
Forum: Woodworking
Hi Rodger, I know you are moving away from the Tangent system but the drawing below is what I would call a Stretch Out of your stairs. It is essentially the stairs folded out at the corner as if on a hinge at the corner so you can see each elevation side by side. The pitch lines are shown for both t...
by Meccarroll
Mon Apr 05, 2021 8:11 am
Forum: Projects
Topic: Past project
Re: Past project
That's a nice start but maybe a new thread? It may be difficult for people to visualise what you are conveying without a wreath section. Without adding a typical application for the drawing it may be difficult to visualise the relevance of such work. Which book are you working from Oldboy22, and ca...
by Meccarroll
Mon Apr 05, 2021 6:23 am
Forum: Projects
Topic: Past project
Re: Past project
That's a nice start but maybe a new thread? It may be difficult for people to visualise what you are conveying without a wreath section. Without adding a typical application for the drawing it may be difficult to visualise the relevance of such work. Which book are you working from Oldboy22, and can...
by Meccarroll
Sun Apr 04, 2021 11:46 pm
Forum: Projects
Topic: Past project
Re: Past project
MJ80 wrote: ↑
Sun Apr 04, 2021 9:05 pm
I've been finding this really interesting to follow along
Don't be afraid to chip in, it is hoped you will!
by Meccarroll
Sun Apr 04, 2021 4:00 pm
Forum: Woodworking
I can't disagree with anything that you've said, Mark. FYI..the lines on the underside are historical. The actual tangent line is marked on the top surface. But even this one shows that, were it correct then cutting the face at a right-angle to it would not butt up with the upper handrail. I take y...
by Meccarroll
Sun Apr 04, 2021 7:31 am
Forum: Woodworking
You have managed to create a very interesting thread here Rodger. I am totally hooked! It’s going to keep you entertained a long time if it carries on like this. Most people spend years learning this stuff and Rodger has come an awful long way (with your help) in a very short space of time, I hope ...
by Meccarroll
Sun Apr 04, 2021 6:49 am
Forum: Woodworking
That's the camera angle, Mark. I had the laser line on the 'extension' and it's all square. The line on your paper next to the letter "B" is the tangent line. The end of the wreath must be squared off to that line (Tangent Line) and your picture shows this to be true. You have added a wedge of poly...
by Meccarroll
Sat Apr 03, 2021 6:59 pm
Forum: Woodworking
It looks like you have decided to manage this with a bit of fettling. What you have been doing in the other thread is beyond my current capabilities, I have only managed wreathes which have the same pitch and although not easy to do I would say they are relatively easy in comparison to your quarter ...
by Meccarroll
Wed Mar 31, 2021 10:13 pm
Forum: Projects
Topic: Past project
Re: Past project
Here’s my version with your dimensions?. What do you think, are the dimensions correct. That looks really good. I'm optimistic ! I think the fruits of this discussion are down to a good teacher (Oldboy22) and student who is determined to learn(thatsnotafestool). Looking forward to seeing the mock up.
by Meccarroll
Wed Mar 31, 2021 7:07 pm
Forum: Projects
Topic: Past project
Re: Past project
Wed Mar 31, 2021 6:47 pm
Is the second to bottom going on the bottom flight similar?...You do mean right down near ground level ?
Bottom flight and Second from bottom Rodger. When you next visit the stairs.
by Meccarroll
Wed Mar 31, 2021 6:25 pm
Forum: Projects
Topic: Past project
Re: Past project
Yes, I found that website, thanks Mark but for this bear with little brain it meant absolutely nothing. And certainly not confident to apply one to my own situation. That's understandable Rodger, I expect you need a break for a couple of days to digest all the drawings. I did a drawing on A4 paper ...
by Meccarroll
Wed Mar 31, 2021 6:11 am
Forum: Projects
Topic: Past project
Re: Past project
Meccarroll Looking forward to what you come up with. This is not my project ..............if it were my choice I'd start over but it's not. .............the whole thing is a nightmare................ Have to wait to see how it all turns out. I took a look at this stair layout in another thread and ...
by Meccarroll
Tue Mar 30, 2021 8:07 pm
Forum: Projects
Topic: Past project
Re: Past project
Meccarroll I agree in an ideal world the stretch-out is the way to go but what’s the point when the bottom step of the upper flight and possibly the second to bottom too, are past the turn and will probably have to be removed and turned into winders. Looking forward to what you come up with. This i...
