Search found 347 matches
- Wed Dec 16, 2020 9:38 pm
- Forum: Woodworking
- Topic: beading for a new floor
Re: beading for a new floor
You would have to notch out the back of the beading wit ha chisel to go around it or remove the patch, at a guess its covering a hole or some sort of damage.
- Sat Aug 22, 2020 7:54 pm
- Forum: Projects
- Topic: Switchboard stand
Re: Switchboard stand
You must have died a little inside getting no replies since posting, lovely restoration
- Sun Aug 02, 2020 10:39 am
- Forum: Projects
- Topic: Recent Staircase
Re: Recent Staircase
Very nice Chris, top draw job
- Mon Jul 08, 2019 1:09 pm
- Topic: External door question
Re: External door question
Peg the tenons.
- Wed May 15, 2019 10:03 pm
- Forum: Non-woodworking related DIY
- Topic: Insulating Roof
Re: Insulating Roof
Yes A and no need to vent at all , i would do a mass fill of rock wool myself, cheaper and easier to fit. I would buy a decent brand though of 170mm like Isover or Knauf. You probably should have some kind of back ground ventilation through the shop though say a low level vent at the front and one a...
- Wed May 15, 2019 9:52 pm
- Topic: Guidance on pricing window repairs please
Re: Guidance on pricing window repairs please
I would massively swerve that one, i am done with polishing turds personally but if it had to be it would be on day work with a guestimate on time given. Other than that i am with Leveller.
- Wed May 15, 2019 6:56 pm
Re: Insulating Roof
Then push it up tight as under the OSB and you wont need to vent it but insulate and seal it well at perimeters so no air can ingress under the Celotex, version B/C you will get condensation between the deck and insulation so will need venting. Unless you can vent from one side to the other dont do ...
- Wed May 15, 2019 1:10 pm
Re: Insulating Roof
Is it a tiled roof or flat roof?
- Sat May 11, 2019 7:36 am
- Forum: For Sale
- Topic: Rotary phase converters
Re: Rotary phase converters
The digital convertor runs the motor on the panel saw just like a proper 3 phase supply, it sounds super smooth compared to the rotary, the digital can just stay on idle and use hardly any electric and has all sorts of parameters set on it ie DC braking times. The rotary is noisy and uses juice when...
- Sat May 04, 2019 2:42 pm
- Forum: Power Tools and Machinery
- Topic: WADKIN MK / RM - OIL GREASE
Re: WADKIN MK / RM - OIL GREASE
Serious bit of kit mate are you gearing up to do joinery full time at some point ?
Btw how did you get on with the waterbourne laquer ?
- Mon Apr 22, 2019 7:39 am
- Topic: shaker door supplier
Re: shaker door supplier
I was going to use Shaker2go Ashford for a wardrobe job the other year but made them myself in the end but after knocking up 32 doors i wish i had!!
- Wed Apr 17, 2019 7:29 pm
- Topic: Apprentice joiner vacancies
Is there anybody here that is Dartford /surrounding areas /south London based who take on apprentices?
I have a friends lad who is looking to get into workshop based joinery, he is 19 and mobile and currently bored silly fixing photo copiers.
Ta
Ta
- Sun Mar 31, 2019 5:33 pm
- Topic: stair spindles
Re: stair spindles
We use abit of glue and a micro pinner for the fillet, on occasion used mitre bond to glue the fillet in place easier if you dont have a brad nailer and less chance of putting dinks in the wood hammering pins in. As Mark said a dab of mastic top and bottom to stop any rattles after abit of shrinkage...
- Tue Mar 26, 2019 9:04 pm
- Topic: AC Laquer / Pre Cat
Re: AC Laquer / Pre Cat
http://rydenor.co.uk/high-performance-w ... e-lacquers
i have bought 501 white primer from there you can also order from Morrels Sittingbourne branch over the phone maybe try there then you can ask any questions you may have.
- Tue Mar 26, 2019 4:50 pm
I have used Morrells waterbourne laquer, very little smell.
- Sat Mar 23, 2019 8:27 am
- Forum: For Sale
- Sat Mar 23, 2019 8:26 am
- Forum: For Sale
- Topic: Crown extraction/guard
- Wed Mar 13, 2019 10:47 pm
- Topic: Dovetail Jig
Re: Dovetail Jig
https://www.ebay.co.uk/itm/Trend-DJ300- ... 3728282248
We got one of the Trend jigs in the link above, rarely used but does the job. Looks like a bargain to me.
- Thu Mar 07, 2019 9:07 pm
- Topic: Felder & Other Machinery on eBay
Re: Felder & Other Machinery on eBay
A little while ago pictures of my Felder planer that i bought through Ebay where used in a listing on Ebay and that's the second time i have seen them now probably other occasions as well no doubt.
Scamming feckers!
Scamming feckers!
- Fri Feb 15, 2019 5:21 pm
- Topic: Festool Domino warning - graphic content
Re: Festool Domino warning - graphic content
Woahh thats nasty, we got the DF500 a short while ago thanks for heads up. I went to East Grinstead to get my thumb sorted after i decided to put it into my power plane, it was on par with your injury i didn't think it would heal as good as it did.... my hearts pounding thinking back on it now. Spee...
- Wed Feb 13, 2019 4:56 pm
- Forum: Wanted
- Topic: Luban Low Angle Block Plane
Re: Luban Low Angle Block Plane
Can you pm me I got some info for you, you may not be able to pm as your a new member.
- Sun Feb 10, 2019 10:14 pm
- Forum: Design/Development
- Topic: Stair Design Software
Re: Stair Design Software
https://www.staircon.com
You seen that one, doubts its cheap but please let me know as i do stairs quite often but just do rough design sketches fir clients.
http://www.ddxgroup.com/en/software/powerstairs
https://www.cadwork.com/cwen/Solutions/Staircase_design
- Fri Feb 08, 2019 6:33 pm
- Topic: Sash construction - Double glazing
Re: Sash construction - Double glazing
As you plan on making a huge saving making the windows yourself why not get a costing on heritage units it will help to keep your window in character and narrower rebates will help keep the meeting rails slimmer, i read that thicker units have double reflections and bulges from pressure and ruin the...
- Fri Feb 08, 2019 6:17 pm
- Forum: Wanted
https://www.workshopheaven.com/quangshe ... plane.html
https://www.rutlands.co.uk/sp+hand-tool ... nds+dk1336
WSH says something about not shipping to North America is that your issue ?
- Fri Feb 08, 2019 3:32 pm
- Forum: Forum suggestions/comments/complaints
- Topic: Bad form or just annoying?
Re: Bad form or just annoying?
Any joinery questions i have Googled(ie:box sashes) in the past i have always ended up here for an answer or a clue at least of what to do so thats why i joined the forum, its not as active as it was sorry to say. You have Woodhave2 also to try.
- Thu Feb 07, 2019 11:37 am
Pretty sure a 16mm softcoat argon/kryton gas filled unit will get you well within regs Google a U value sealed unit chart, yes to 15mm rebate and a 3mm gap all round the unit. You said you got 40mm thick sashes I would thicken them to 44mm if your going to totally renew the window. Not keen on exter...
- Sun Feb 03, 2019 6:35 pm
- Topic: Replacement Sash and Case Windows
Re: Replacement Sash and Case Windows
You can buy redwood Vac Aqua treated profiles from here http://www.expresstimberproducts.co.uk/index.php?page=Sash---Case-Window-Sections, not what i would go for myself because the treatment doesnt go right through the wood so any cuts you make ie: mortice and tennon joints... infact any cuts you w...
- Sun Feb 03, 2019 10:02 am
In general what condition are the sash boxes in especially where the cill and linings meet....the usual areas for decay.
- Sat Feb 02, 2019 7:13 pm
- Forum: Wanted
Are you talking about the type 3?
- Thu Jan 31, 2019 8:38 pm
- Topic: If you had to choose a combi machine?
Re: If you had to choose a combi machine?
I would go for a Felder, i got seperates myself, whats your budget ?
https://www.ebay.co.uk/itm/FELDER-CF-53 ... :rk:6:pf:0
- Mon Jan 28, 2019 10:27 pm
Where are you located as you could be lucky that one of us could be local to you that make them.
- Mon Jan 21, 2019 8:22 pm
- Forum: For Sale
Re: Crown extraction/guard
PM sent
- Wed Jan 09, 2019 7:31 pm
- Topic: Viceroy sharpedge
Viceroy sharpedge
Anybody got one ? the one i have has the conicle stone on the side no use for it though as yet. When i bought it i was given a tub of this amber pungent smelling fluid the stuff i think we used on the metalwork lathes at school back in the 80's. Anybody know what the cutting fluid is called as i nee...
- Sun Jan 06, 2019 7:22 pm
- Topic: Pull saw recommendations?
Re: Pull saw recommendations?
https://www.axminster.co.uk/shokunin-ja ... 0mm-105013
I use the Hassume which Axminster used to do also bought the rip blade to go with it, lovley cut though the difference between a Kataba and Hassume i cant tell you.
- Sun Jan 06, 2019 6:15 pm
- Forum: Projects
- Topic: fired earth style kitchen
Re: fired earth style kitchen
Very nice, got a my own kitchen in the pipe line to do just cant settle on what style to follow.
- Sun Jan 06, 2019 6:11 pm
- Forum: Projects
- Topic: Small boot room
Re: Small boot room
Grand job mate.
- Sun Jan 06, 2019 12:20 pm
- Forum: For Sale
Its approx 340mm, the bench is an 8 x 4 for general sizing.
- Mon Dec 31, 2018 2:12 pm
- Forum: For Sale
£20 now, money will go to New Hope animal rescue.
- Sun Dec 16, 2018 3:23 pm
- Topic: Hammer C3-31 dished fence
Re: Hammer C3-31 dished fence
I made do with my Kity 637 for a long time and it was less of a PITA when I removed the extraction chute and used a home made hood when thicknessing and one for surfacing which was clamped by thicknessing table. Maybe try removing yours and see how it goes before shelling out. I got a Felder silent ...
- Mon Dec 10, 2018 10:50 pm
- Forum: Wanted
- Topic: Looking for Hardwood shop.
Re: Looking for Hardwood shop.
http://www.exotichardwoods.co.uk
Could be worth a try.
