Search found 195 matches
- Sat Jul 25, 2020 5:22 pm
- Forum: Projects
- Topic: Desk - tracing a three minutes sketch
Re: Desk - tracing a three minutes sketch
Lovely work, wold like too see more
- Sat Jul 25, 2020 4:35 pm
- Forum: Projects
- Topic: Recent Staircase
Re: Recent Staircase
Have been wanting to post these for a while now, images of the completed flight https://i.imgur.com/0GMlmwC.jpg https://i.imgur.com/pIP987s.jpg https://i.imgur.com/8VbrqSe.jpg https://i.imgur.com/dFTQPdT.jpg https://i.imgur.com/804C0bs.jpg https://i.imgur.com/zBJH5jB.jpg https://i.imgur.com/q3No9Ld....
- Sun Apr 12, 2020 11:54 pm
- Forum: Hand Tools
- Topic: Stanley(made in England) no 4 plane, replacement parts
- Sun Apr 05, 2020 8:18 pm
- Forum: Projects
Thanks for all the kind and encouraging comments its appreciated TNAF this may interest you, one I did last summer Was asked to quote for a new oak staircase. my first question was "are you going to carpet it" yes was the reply. I said "then you don't need a new staircase and this is what I did firs...
- Tue Mar 31, 2020 8:34 pm
- Forum: Projects
Recent Staircase
Thought I would like to share the build of this flight of stairs This staircase and balustrade also acts as the support for the upper landing with the client wishing to maintain a view to some original leaded windows found in the property (which dates from the 18th century and was originally a pub/I...
- Sat Sep 28, 2019 3:34 pm
- Forum: Woodworking
- Topic: Hipped roof pitch help please
Re: Hipped roof pitch help please
These may help
Plumb/foot cuts on both rafters and jack rafters are the same
- Wed Apr 17, 2019 11:06 am
- Forum: Projects
- Topic: driveway gates
Re: driveway gates
you would create a haunch in a wide tenon more to strengthen the mortice as in certain cases the mortice walls are thin and need bolstering in the middle this is purely subjective to the thickness of the material. In my case with six inch rails and 60mm+ thickness of material a central haunch in my ...
- Tue Apr 09, 2019 8:44 pm
- Forum: Projects
Re: driveway gates
Haunching is usually carried out on a corner joint say the top and bottom rail of a door so as to completely contain the tenon in the mortice, on wide rails (usually middle rails) the haunch is usually in the middle of the rail thereby preventing the need for an overlong mortice. The short tenon on ...
- Sun Apr 07, 2019 6:33 pm
- Forum: Projects
Re: driveway gates
bit of a wet day but just been out to take a few photo's https://i.imgur.com/5NjHUe9.jpg https://i.imgur.com/KcZlNsO.jpg absolutely no sagging of the gates or movement on the posts the only issue which does not concern me too much is that the auto closers needed to be place high up to so as to go ab...
- Sat Mar 02, 2019 9:02 pm
- Forum: Power Tools and Machinery
- Topic: Saw blades for Radial Arm Saws
Re: Saw blades for Radial Arm Saws
I would suggest you need a crosscut blade with chip limiters (this restricts how much material each tooth takes during the cut and prevent ride up)
- Tue Feb 05, 2019 11:09 pm
- Topic: Replacement Sash and Case Windows
Re: Replacement Sash and Case Windows
Rich
With a felder you will need a minimum of a chip extractor as the cutters will block up and seriously effect the timber finish. modern machines are designed to work with extraction as they throw all the spoil in the direction of a 100/125mm pipe
- Tue Feb 05, 2019 1:54 pm
Hi You would not go far wrong with this (or something like) at the right price https://www.ebay.co.uk/itm/FELDER-BF6-26-Combination-Woodworking-Machine-on-360-degree-turntable-240-v/273681270438?hash=item3fb8acc6a6:g:G~gAAOSw7C5cVDNl:rk:1:pf:1&frcectupt;=true I'm on my third combi the last two being ...
- Thu Jan 24, 2019 8:22 pm
- Topic: Marks on wood door
Re: Marks on wood door
oxalic acid powder (which you dissolve in warm water) or liberon wood bleacher (which is prepared oxalic acid)
- Fri Dec 28, 2018 2:04 pm
- Topic: Hammer C3-31 dished fence
Re: Hammer C3-31 dished fence
Glad to be of help.
Its good that we can all learn from each other, its what forums are for
- Thu Dec 27, 2018 4:33 pm
- Topic: Table Saw (£400 budget)
Re: Table Saw (£400 budget)
just my two penneth If you are cutting full sized sheets (8 x 4) on a £400 table saw you are going to struggle and the initial cuts will not be very accurate. I also use a Felder with a sliding table however for the initial cuts I start with a dewalt track saw and a 2.7m track. Its far easier to car...
- Mon Dec 17, 2018 6:53 pm
Thanks for the link to that thread which I missed first time round. I'm going to look forward to reading that. It's a good tip but had you thought of a power feeder on your planer ? This is mine with a 4.4m length of timber being prepped for skirting. (bottom LH corner) https://farm5.staticflickr.c...
- Sun Dec 16, 2018 10:30 pm
I'm on my third combination machine and my second Felder and whilst I can see the point of some of the above comments and essentially agree I run a combi due to workshop size That being said and being a one man band one advantage I have exploited is the use of a long sliding table with the spindle. ...
- Sat Oct 20, 2018 11:17 am
- Topic: Silicon Spray
Re: Silicon Spray
Wax polish works for me, also keeps them slick
- Sun Aug 19, 2018 11:51 am
- Forum: Hand Tools
- Topic: Router Plane Lubricant
Re: Router Plane Lubricant
https://www.axminster.co.uk/axcaliber-d ... ant-503468
- Wed Jul 18, 2018 10:38 am
- Forum: Wanted
- Topic: Whitehill Block (old style)
Re: Whitehill Block (old style)
this picture may help https://i.imgur.com/MGJbbdT.jpg Because the cutter is further away from the centre line of the block when the cutter is 90 degrees to the fence then when it hits the timber it hits it at more of an acute angle so for example if cutting a quarter round then in height from the be...
- Wed Jul 18, 2018 1:58 am
- Forum: Wanted
One final thing, because the cutter is mounted further away from the centre than modern pinned blocks the shape of the cutter will not be the same as the moulding produced
- Wed Jul 18, 2018 1:45 am
- Forum: Wanted
don't want to teach you how to suck eggs however if you have not used these blocks before a couple of tips if I may. I assume you are using a pair of cutters, balance is important with these blocks so getting the two cutters in place accurately is important. I use an L shaped ply slip drawing around...
- Mon Jul 16, 2018 8:43 pm
- Forum: Wanted
they appear on ebay from time to time (i think you just missed one) however if you want I could lend you one (believe you are in Kent)
- Sun Jun 17, 2018 3:29 pm
- Topic: Rubbing down solid oak door - how far?
Re: Rubbing down solid oak door - how far?
Try cleaning it off with some oxalic acid diluted with warm water, that should get rid of any black marks and revive the timber.
You then need to neutralise with water, let it dry and cut back the raised grain prior to finishing
- Thu May 03, 2018 4:28 pm
- Forum: Projects
Re: driveway gates
An update too this. I appreciate there has been a delay in getting these swinging, the main reason being I spent the majority of the winter in Australia and if I had hung them prior to going I would not have been able to monitor any movement in the boards and take any remedial action as needed. Anyw...
- Thu Jan 04, 2018 2:01 pm
- Topic: Replicating square balusters
Re: Replicating square balusters
This is the only cost effective way of replicating square balusters I know of, however pretty specialist
https://www.instagram.com/p/BQ0COylguCq ... d=therming
You could try Richard Findley
- Fri Dec 22, 2017 7:25 pm
- Forum: Projects
Re: driveway gates
Thanks for all the nice comments/constructive criticisms and advice, its all very much appreciated. Where we are at the moment is, I have had delivered two pair of 900mm adjustable hooks and bands. They were advertised as being galvanised and powder coated however the coating was flaking a little (d...
- Thu Dec 21, 2017 9:25 pm
- Topic: Timbmet...................
Re: Timbmet...................
Have been to JW timber a few times, unfortunately they no longer supply AW oak just European, however for service I cannot fault them. The last lot of Oak I bought(What i built the gates from here http://www.woodworkuk.co.uk/forum/viewtopic.php?f=9&t;=13444) was from http://oakandwood.co.uk/ They do ...
- Tue Dec 19, 2017 10:07 pm
Aren't Timbmet now owned by Meyers??? There used to be a Meyers close to me in Strood, Kent, that closed. I then started using Timbmet in Larkfield, Kent and on being taken over they closed that branch. Being a one man band with limited storage I only collect materials, don't have anything large del...
- Mon Dec 11, 2017 10:11 pm
- Forum: Projects
Re: driveway gates
I'm not at the moment. they were just about manageable prior to boarding however now boarded I need someone to help me move them about.davidpidge wrote:Fantastic WIP photos. They are some monster bits of joinery! How are you moving them around?
- Mon Dec 11, 2017 10:08 pm
- Forum: Projects
Re: driveway gates
Very impressive matey. The only thing I would be concerned with is the expansion gap between the boards. From personal experience I don’t think that 1.5mm will be enough - I’d have gone for 3mm and treated them before assembly. I hope I’m wrong as they really do look the business. Yes that's someth...
- Mon Dec 11, 2017 9:17 pm
- Forum: Projects
driveway gates
Driveway Gates I’ve just completed a pair of driveway gates. These are for myself and are part of a long ongoing project whereby I have created a new driveway. This has included digging out a few tons of earth, laying brick retaining walls which included elements of curved brickwork, laying approx 1...
- Mon Dec 04, 2017 10:55 am
- Topic: cutting straight with a bandsaw
Re: cutting straight with a bandsaw
Stenner Band-Re-saw would cut through this in about one minute your Bandsaw 20+ I'd say.............? Stenners I've seen approx 10-20 secs for an 8' length my setup 2-3 mins 2-3 minutes is Much quicker than I thought. Perhaps I should buy some blades like you as I have some odd blocks of oak that I...
- Mon Dec 04, 2017 10:44 am
hope this helps
- Sun Dec 03, 2017 11:51 pm
Nearly right, its this one http://www.ikea.com/gb/en/products/lighting/work-lamps/jansj%C3%B6-led-work-lamp-black-art-00169659/ I've replaced the supplied weighted base with a piece of timber and super-glued two 25mm rare earth magnets into the new base. Works a treat and rock solid, stays where you...
- Sun Dec 03, 2017 12:40 pm
The attached was resawing kiln dried 6" and 8" euro oak 8' long. the machine is a Meber 500 with a approx 20" throat and 12" depth of cut, single phase with a 2hp motor. https://i.imgur.com/JrdsWth.jpg As you can see I used supports both front and rear which are essential for this type of cutting (...
- Sun Dec 03, 2017 11:27 am
The attached was resawing kiln dried 6" and 8" euro oak 8' long. the machine is a Meber 500 with a approx 20" throat and 12" depth of cut, single phase with a 2hp motor. https://i.imgur.com/JrdsWth.jpg As you can see I used supports both front and rear which are essential for this type of cutting (e...
- Wed Oct 04, 2017 1:03 pm
- Topic: British Carpenters Jargon
Re: British Carpenters Jargon
How about, "gun-stop joint" , that's a pearl for you. It's a diminishing joint in the middle rail/stile of a door. Levelle r is the man to explain the joint to you, but he has not yet entered this thread. Mark In the absence of leveller and if I may, its actually known as a gunstock stile (as the s...
- Tue Aug 22, 2017 10:49 pm
- Topic: Iroko Worktop
Re: Iroko Worktop
I've used both PU and Titebond 3 on iroko worktops successfully.
One suggestion is to wipe the joints with thinners then let it evaporate prior to gluing, this should remove any oils contained in the timber which could affect the adhesives abilities
- Fri Jun 30, 2017 6:58 pm
- Topic: Felder BF5 planer bearings
Re: Felder BF5 planer bearings
PM sent
