Search found 2892 matches
- Thu Oct 26, 2017 10:21 am
- Forum: For Sale
- Topic: Band saw help please
Re: Band saw help please
what size boxes ? .. you have to have room for the wood you are cutting as well as the machine. So think about the placement on the shed too. You can have a long piece of wood sticking out the door/window if needed when cutting etc. edit , just googled, I know the type of box you mean now ! you will...
- Wed Oct 25, 2017 3:24 pm
- Forum: Finishing
- Topic: Wood filler
Re: Wood filler
surely the pocket holes will be on the inside , and so , not seen ?
- Sat Sep 23, 2017 2:10 pm
- Forum: Power Tools and Machinery
- Topic: Jigsaw
Re: Jigsaw
it might be fiddly .. but you might be able to get the part and swap everything over ?
- Mon Sep 18, 2017 4:53 pm
- Topic: Cordless had saw
Re: Cordless had saw
have you considered and ruled out a generator ?
- Fri Aug 18, 2017 9:23 am
- Forum: Hand Tools
- Topic: Wood too big for mitre box...
Re: Wood too big for mitre box...
Depending on how much you intend to use it, and how big the wood is you want to mitre, you might benefit from buying one of these http://www.clasohlson.com/uk/Nobex-Mitre-Saw/40-8892?gclid=CjwKCAjw_dTMBRBHEiwApIzn_K4JW041sr_i_F5cSM6dfITyiEyaoHXy2pHLtUIZGitIkOs1Y0d4thoCA-YQAvD_BwE - other suppliers ...
- Thu Aug 17, 2017 4:08 pm
- Forum: Hand Tools
that's the way you will start to think when you work with woodCaptainBungo wrote:Oh wow... I feel slightly embarrassed that I didn't actually think of that. Always trying to over complicate things
- Wed Aug 16, 2017 4:01 pm
- Topic: Spraying advice
Re: Spraying advice
if you ever watched TOH .. they used it (spray) all the time on empty rooms .. you know .. the usa .. using nail guns when we still had hammers ! lol
- Tue Aug 15, 2017 4:49 pm
- Forum: Hand Tools
put a list of tools you have .. that might help
- Tue Aug 15, 2017 4:48 pm
- Forum: Hand Tools
you could make a bigger mitre box quite easily.
1st things we learned in school wood class was mitre box, bench hooks etc .. have a google .. quite straight forward
- Sun Aug 13, 2017 12:32 pm
- Forum: Wooden boats
- Topic: Building a Paradox
Re: Building a Paradox
doug fir ?
it's berried in my memory banks somewhere, that that is a suitable wood to use for a keel.
- Thu Aug 03, 2017 6:11 pm
- Topic: Top makes of saw blades ?
Re: Top makes of saw blades ?
a better answer might inspire better replies !Henry wrote:Cutting woodbigdanny wrote:For what?
- Mon Jul 24, 2017 1:49 pm
- Forum: Woodworking
- Topic: Church Notice Board
Re: Church Notice Board
Pressure treated softwood, will be cheaper than hardwood. at least for the posts ?
I'd go for laminated glass over tempered. It's cheaper, and doesn't make a mess if it get broken.
Most notice boards I've seen are very simple things.
- Fri Jul 21, 2017 4:39 pm
- Topic: Help with hinges...
Re: Help with hinges...
you could rebate / groove to have them hidden in the legs .. just a suggestion to use a stay that might not be intended for this use
- Fri Jul 21, 2017 11:52 am
couldn't you use any hinge, along with some stays .. either top cupboard type .. pasting table type etc etc .. there is a lot of fold up camping type furniture to look at too
- Wed Jul 19, 2017 9:01 am
- Topic: new dust mask / respirator ?
Re: new dust mask / respirator ?
ah, ok .. same as mine then.
the P is for particulates. 1,2,3 .. with 3 being the best / removing the most
I'll have to look at removing dust more at source. And also use my air cleaner again.
- Tue Jul 18, 2017 5:53 pm
yes , a little bit reasuring .. they do a P3 prefilter , but can't find it in this country.
about £5 a pair from the nether regions .. plus post.
So might get the one Steve said about, for when using MDF only
- Tue Jul 18, 2017 5:47 pm
- Topic: Options on a combi
Re: Options on a combi
you can add a DIY DRO with a cheap digi caliper
- Tue Jul 18, 2017 5:43 pm
- Topic: Photobucket
Re: Photobucket
indeed it is Nick ! .. right and royally they done it too !
- Sun Jul 16, 2017 3:56 pm
Looks like I'll be getting something more suited to MDF dust ......
- Sun Jul 16, 2017 3:36 pm
this is the cartridge
http://www.gersonco.com/product/gerson-g02e/
and this is the prefilter
http://www.gersonco.com/product/gerson- ... d-082814c/
you know .. I never considered it before ? I have no idea why not ...
- Sat Jul 15, 2017 11:45 pm
Cheers Steve . Mine are comfy . When the CNC is going I wear it all day practically . It was more that I've been buying/using the same system for about 10 yrs , that I thought I'd check and see what everyone else is using these days Price wise, the replacement cartridges for mine are about £18 ish, ...
- Sat Jul 15, 2017 5:35 pm
just getting ready to buy a new mask/ or cartridges for the one I have. which is this one http://www.ebay.co.uk/itm/Gerson-9000E-Series-Respirator-Face-Mask-Free-UK-Delivery-Model-9213E-/281596029851?hash=item41906e6b9b:g:B1QAAOSwH09ZJZsj has twist on cartages, and disposable prefilters .. I used to...
- Sat Jul 15, 2017 5:13 pm
- Topic: Y join
Re: Y join
what size ?
could you make a small Y half the thickness and half lap the joint ?
How thick ? Biscuits / dominoes / dowels might do ?
- Wed Jul 12, 2017 8:55 am
Re: Photobucket
yep .. all over the world, people are being photofucketed .
I haven't seen anyone say they will pay though.
I don't know if they actually thought people would or not, but they've totally screwed every forum ever
- Sat Jun 24, 2017 7:44 am
- Topic: A job for CNC ?
Re: A job for CNC ?
image not working for me ?
- Fri Jun 23, 2017 5:50 pm
- Forum: Wanted
- Topic: Homework For A Dremel User
Re: Homework For A Dremel User
you got any photo's ?
what kind of plastic ?
it maybe cheaper to get some new cubes laser cut, with the holes already in
- Wed Jun 14, 2017 9:11 am
- Topic: Mahogany arches
Re: Mahogany arches
depends on the kit you have , and you ability ?
Screwed from the outside and glued would last a while.
I'd put some slight flats on the arch where it meets the bracket, whichever way you chose to join.
- Tue Jun 13, 2017 9:40 am
- Topic: CNC ROUTERS
Re: CNC ROUTERS
ah .. a proper one !
there are a few members on here that have them.
MarkNumbers, Sainty, come to mind. York33 built his, as did I, so I can't comment on the proper ones sorry.
Treat them like an employee .. then after a year or two of "paying them" , they work for nothing !
- Mon Jun 12, 2017 10:04 pm
Re: CNC ROUTERS
it depends what you will use it for, how much you have to spend, and what space you have to put it.
- Tue May 23, 2017 1:43 pm
- Topic: Feeling Lucky ! Finished
Re: Feeling Lucky !
very nice on all counts !
- Mon May 22, 2017 10:24 am
- Topic: Which pillar drill?
Re: Which pillar drill?
Hi everyone. First time on. I've started a project and realised I need a pillar drill. A small bench drill would be ok as my project is small. I used to have a budget buy drill that I got from Machine Mart but it was not really very good for several reasons. A machine that is a little better qualit...
- Thu Apr 27, 2017 1:16 pm
- Topic: Cutting Cardboard Tubes
Re: Cutting Cardboard Tubes
Here are some ebay sold listings
http://www.ebay.co.uk/sch/i.html?_from= ... be&_sop=13
- Thu Apr 27, 2017 1:13 pm
if they are clean, stick them on ebay ! .. I'd be surprised if you couldn't sell them.
Or advertise them in a free paper for free local collection
- Mon Apr 24, 2017 10:25 am
- Topic: Workbench clean up?
Re: Workbench clean up?
I was thinking that .. I'd much rather have the patina and history that it must havenickw wrote:It's a workbench. What does a bit of discolouration matter?
- Fri Mar 17, 2017 6:43 pm
- Topic: Deep ripping timber - time issue
Re: Deep ripping timber - time issue
How about as the woodyard for 2 consecutive planks ? (if they cut thier own .
Whitmores do, and will let you select your own
- Fri Feb 24, 2017 12:04 pm
- Topic: Rip blade vs Crosscut blade
Re: Rip blade vs Crosscut blade
a blade will rip or cut exactly the same for a pro or a hobbyist !
along with the same quality of cut ..
and safety issues !
it only take a minute to change a blade . But if you can't be bothered, then at least get a combi cut blade.
and safety issues !
- Thu Feb 16, 2017 9:27 am
- Topic: In frame door stops
Re: In frame door stops
they ship to UK ?
or, can't you just use a round with of wood/ply/mdf, with an offset hole ?
- Tue Feb 14, 2017 1:16 pm
- Topic: End grain cutting board - when oiled it bows
Re: End grain cutting board - when oiled it bows
was the wood dry before you started ?
- Tue Feb 14, 2017 10:14 am
I presume you are oiling both sides equally ?
1st oiling should be flooded on and left for a while before wiping off the excess
- Sun Feb 12, 2017 6:08 pm
- Topic: good earners
Re: good earners
Hello all Can you tell me all your best selling products please, I'll be semi retired, so I can make them cheaper and take all your customers thanks :lol: :lol: Seriously, have a look at the places you will likely be selling, and see what is selling there (that you would like to make). Then decide ...
