Any one build own wooden boats, or know wood very well?
james weld
Postby james weld » Sat May 08, 2010 6:47 pm
Hello guys,
I am building a 10 foot wooden jon/skow. I just need help on how much wood to get, and what dimensions to get. The plywood is 3/4 in, I have the wood for the seats, and I am going to be using spruce instead of oak. If any one could help that would be great. Thanks a lot!
_____________________
Patio Furniture
DavidO
Site Admin
Re: Any one build own wooden boats, or know wood very well?
Postby DavidO » Sat May 08, 2010 7:14 pm
You'll need to be a bit more specific if you want people to work out how much wood to get. I know there are perhaps 2 people on the forum that have boats, but most of us do not. I had to google just to find out what a skow was, and then I found your question on a number of other forums along with a PDF...
http://www.vintageprojects.com/boats/jon-boat-plans.pdf
Along with the answers:
Looks like you need three sheets of 6′ x 4′ ply at least, and at least 60′ of chine logs,stringers etc.
2 sheets of 1/4 inch ply for sides and 2 sheets of 3/4 for bottom and transom, pine gunwales and other inserts
What else do you need to know or do you just need more detailed sizes?
I personally haven't got a clue, but the overall design looks fairly simple so if you tell us what bits you need dimensions for then someone will be able to help you out.
peter radclyffe
Postby peter radclyffe » Thu Jun 10, 2010 11:34 pm
can you get john leathers book , clinker boatbuilding
Return to “Wooden boats”
