Paulownia Raw Wood / Timber
Got something you want to offer to others , here's where to advertise it
Rooted Origin
Postby Rooted Origin » Tue Mar 08, 2011 12:38 am
Hello,
I m selling Paulownia Raw Timber.
Lighe Weight: At only 18 Ibs p/cubic ft . Paulownia wood is lighter than oak (44 Ibs p/cubic ft) and pine (30 Ibs p/cubic ft)
High fire resistance: Ignition temperature app. 425 deg C (Average softwood: 257 deg C. Average hardwood: 223 deg. C)
Easily dried in short time with less drying defects. Kiln dries in 24-48 hours.
Air dries in 30-60 days with no fear of warping, cracking or splitting.
Paulownia Porosity: 75-88%, Loblolly pine 62%, Aspen 73%, Yellow Poplar 71%
Highly durable/decay resistance under non-ground contact conditions.
Chemical composition: Cellulose 46-49%, Hemicellulose
Pentozan 22-25% Lignin 21-23%
Density 10 moisture content 17.91
Specific Gravity 0.265
press strength max. (along the grain direction) 18 - 22.8 N/mm2
pull strength max. (along the grain direction) 38.7 - 59.4 N/mm2
shearing stress max. (along the grain direction):
diameter direction 3.5 - 5.5 N/mm2
chord direction) 3.6 - 5.5 N/mm2
statics bent ( chord direction):
strength max. 30.5 - 40.7 N/mm2
modulus of elasticity 3.0 - 5.9 N/mm2
Prices in GBP 1to9 10to24 25to100
5%off 10%off
Raw Paulownia Wood 2000 mm 150 mm 30 mm 27,60 26,30 25,10
Raw Paulownia Wood 2000 mm 146 mm 26 mm 24,90 23,80 22,70
Raw Paulownia Wood 2500 mm 150 mm 30 mm 34,20 32,60 31,10
Raw Paulownia Wood 2500 mm 150 mm 25 mm 31,60 30,10 28,70
Raw Paulownia Wood 2500 mm 150 mm 15 mm 20,90 19,90 19,10
I use it to built surfboards.It is very light, yet strong and flexy and does not soak up water as fast as balsa.
if you are interested,
PM me or send me an email to
[email protected]
I based in Newquay / Cornwall.
Happy Days,
Christian.
guy
Re: Paulownia Raw Wood / Timber
Postby guy » Fri Jan 20, 2012 3:26 pm
Hey Christian
I'm looking at making a few Alaia's, what price for a 8' x say 20" plank?
Bear with me, I don't buy wood often ;0)
Guy
silveryogini
Postby silveryogini » Thu Mar 28, 2013 2:04 pm
Hi I am interested in this wood to create a lightweight but strong yoga product, finished cut dimension will be 220x115x75mm
can we buy planks to have cut to this finished size, what are your minimums, the cost per cubic metre and carriage costs
or could you cut to this dimension?
Kind regards
Bernadette
Yoga Trading Brighton
Postby promhandicam » Tue Apr 02, 2013 8:04 am
Welcome to the forum Bernadette. I suggest that you contact Christian direct as he isn't a regular contributor here. If you need any further help producing the product you require then I'm sure that others here may well be able to help.
Best wishes,
papajoe
Postby papajoe » Mon Jun 17, 2013 7:15 pm
Nice, been using it for years for alaias and paipos and finally run out of stock!
https://www.facebook.com/photo.php?fbid=10152580803020597&set=a.10152580802435597.952073.670605596&type=1&theater
Cheers Joe
Postby promhandicam » Mon Jun 17, 2013 8:46 pm
Welcome to the forum Joe. Must admit I had to google Alaia's and Paipo's as your facebook link doesn't work, although that may be because I don't use FB. Perhaps you can share some photos of boards that you've made.
papajoe
Postby papajoe » Mon Jun 17, 2013 9:22 pm
Thanks Steve, I'm looking forward to some good postings, here we are. Here's a few images. even though they look simple, there's a lot of magic that goes in them.
Cheers Joe
sawmillsam
Postby sawmillsam » Mon Sep 07, 2015 2:33 pm
Hi i know this thread is really old but i really want to get some paulownia. anyone know where i can get some in uk
Cheers Sam
tinytim1458
Postby tinytim1458 » Mon Feb 01, 2016 12:51 am
Hi do you have any wood left that I could buy.
Thanks Tim
Return to “For Sale”
