Hi all,
I have decided to make some bird feeders this Christmas out of a small log and I am trying to figure out what tools I might need as I have no tools at all (not even a screwdriver) and I have never tried to make anything out of wood before. The log is 27cm (10.6”) in circumference and I want to hollow out the middle of the log by 8cm (3.14”) wide, 14cm (5.5”) length and 7cm (2.7”) in depth. I will then fit some wire mesh over the hollowed out section and drill a hole in the back so I can insert the bird food. I can’t figure out if I can make this hollow with a gouge or if I need an adze. I don’t want to buy both as the tools are expensive and I don’t know how much I will use them after making the bird feeder. Although I do like the idea of making a bowl... Depending on what you recommend gouge or adze what size would you suggest I buy.
Thanks for any advice or help you can offer.
Many thanks,
gouge or adze
Rogerdodge
Re: gouge or adze
I really would not recommend an adze - there is a definite knack to using one which takes a while acquire - meantime your toes are at risk ! ( I am talking about the traditional long handled boat builders adze. )
Good Luck
Rog
Good Luck
Rog
Re: gouge or adze
spade bit and hand drill to hog the most out. then a chisel/gouge (or power file! )
Re: gouge or adze
if you don't want to spend any money then a gauge is your best bet.
