Painting Metal....NOT WOOD
rhrwilliams
Postby rhrwilliams » Mon Mar 07, 2016 8:09 pm
Hi, I am restoring a old commercial Gaggia coffee machine to put in my kitchen.
Anyway, I want to re-spray the galvanised metal panels Ferrari red, and want to do it with my HVLP. The existing paint is knackered in areas.
What is the best paint to use ? I started researching but I'm slightly confused by it al, 2 pack, cellulose etc etc l. Also, do I need to remove all the old paint or can I just sand down thoroughly with wet and dry up to 400 grit and paint over. ?
Any help would be appreciated. If its too complicated to do at home I can pay a local firm to do it but id prefer to do it myself.
Richard
Re: Painting Metal....NOT WOOD
Postby JonR » Mon Mar 07, 2016 8:34 pm
What about chemically stripped then powder coated maybe.
rhrwilliams
Postby rhrwilliams » Mon Mar 07, 2016 8:53 pm
Thanks Jon - you know of anywhere locally that does that sort of thing - this one might be a job for the pros
Postby tusses » Mon Mar 07, 2016 9:21 pm
google your local Jawel
https://www.jawel.co.uk/
they can mix paint and put it in rattle cans from small jobs like this
celly is safer than 2K, which will kill you without proper filter masks
rhrwilliams
Postby rhrwilliams » Sun Mar 13, 2016 7:56 pm
Thanks , ill give them a try. I started stripping the old paint off - what an awful job stripping paint is !
rhrwilliams
Postby rhrwilliams » Mon Apr 18, 2016 7:49 pm
I stripped by hand (took aggggggges) bought the paint mixed from local spray store and sprayed it from sprayer - and it turned out OK
I'm well pleased .
Rogerdodge
Postby Rogerdodge » Mon Apr 18, 2016 8:12 pm
Nice.
