Can I use car paint on top of a wood primer?
york33
Postby york33 » Fri May 15, 2015 12:44 pm
Afternoon all
Anyone know if I can use a car paint on top of a normal waterborne primer (for wood)? Just a bit of a random request to spray some furniture funky metallic colours?
Figured there's a huge amount of readily available funky coloured car paint and I couldn't think why not!
Dave
Re: Can I use car paint on top of a wood primer?
Postby mark270981 » Fri May 15, 2015 1:12 pm
I have used car paint on timber before but using all the relevant primer etc, worked well.
If no one can answer there is only one way to find out.
Jawel paints is always a good place to start.
york33
Postby york33 » Fri May 15, 2015 2:19 pm
Thanks Mark, good enough for me. I've told them yes, no problem at all - as you do - and will find out if it's possible if they confirm order :-)
sammy.se
Postby sammy.se » Fri May 22, 2015 5:44 am
I've used car lacquer on top of acrylic paint and it messed it all up (the paint below dissolved and warped) so I'd suggest using car primer/paint/lacquer and not using waterbased... but good luck, let us know how it turns out...
templecarpentry
Postby templecarpentry » Thu May 28, 2015 9:19 pm
I have used 2pac over precat primer. It was fine.
Check out my website here http://www.templecarpentry.co.uk
My other new website is now up and running http://www.shaker2go.co.uk
And my blog here http://www.templecarpentry.co.uk/blog.html
york33
Postby york33 » Sat Jun 06, 2015 10:39 am
Apologies, delayed reaction! Well, they've signed up for it, so we'll find out in a couple of months when I get onto making/painting.
Do you actually get much in the way of waterborne car paint? I thought the world had moved that way, but Google says no! I was going to stick with that as that's what my 'normal' paint is.
I had a look at Jawel paints, more confused, 2K (is that 2 pack?), 2K none iso, cellulose, synthetic.......taking the various H&S issues as a given, which one should I get?
templecarpentry
Postby templecarpentry » Sun Jun 14, 2015 11:36 am
york33 wrote:Apologies, delayed reaction! Well, they've signed up for it, so we'll find out in a couple of months when I get onto making/painting.
The paint world is leaning toward water based now. It's part of a legislation move regarding the voc content. In the next decade it will more than likely be illegal to spray anything else other than water
So in answer yes there is plenty of water based about. Expect it to be more expensive though. Don't ask me why.
hungover
Postby hungover » Sat Aug 22, 2015 9:01 am
2K is two pack.
My experience is limited to the ones containing isocyanates. Evil stuff (with respect to your lungs) but great to work with.
