So I'm not so much of a woodworker, but I tinker.
I've made a drinks coaster. So yes its just a square of wood 20mm thick, but I've hand decorated with a pyrography pen and I'm happy with the result. Some self adhesive on the base and it looks quite smart.
I'm thinking as a coaster it needs (or doesn't?) some kind of protection? I was goign to apply some wax over the top surface. So my questions are
Is that the right thing to do (to protect from rings from cusp etc) - maybe it wont make any difference?
If I apply the wax do I then simply buff by hand or do I use a buffing wheel on a bench grinder that I have ?
thanks,
Smee
bit of wax on oak?
Re: bit of wax on oak?
Wax is not a durable finish, and not suitable for use under e.g. hot cups. Hardwax oil (e.g. Osmo Polyx) would be a better bet. Do read the instructions about disposal of rags, and do apply 2-3 coats as thinly as you possibly can with a rag, allowing to dry between coats, and light sanding with p180 or finer, between coats.
thank you.
When I google Osmo polyx hardwax oil I get a lot of Osmo variants - is the difference simply the finish (ie matt, satin etc) - I guess what Im asking is is there a right or wrong one to buy (aside of matt satin etc)
https://www.google.co.uk/webhp?sourceid ... ardwax+oil
On oak its going to raise the grain isnt it - hence the rubbing back?
Lastly you say apply as thin as possible - should I be thinnning it with something?
Smee
Smee
Just go for Osmo 3032 original or 3232 quick drying, apply with a brush and then aftera mminute or two wipe off with paper towel until surface is touch dry. When fully dry light rub down to denib and repeat.
thats great, thanks
Smee
Smee
ok so this worked a treat, thanks. Looks nice
Can I apply wax on top if I want to - just a personal thing but I like the wax finish
Smee
Smee
Thanks. I went ahead and tried and am quite happy with it
Smee
Smee
