Paintable silicone sealant
Can anyone recommend an external silicone which is paintable?
Re: Paintable silicone sealant
Not silicon but an exterior sealant. Acrylic.
http://m.screwfix.com/p/no-nonsense-ext ... tered=true
MS polymer
jake wrote:MS polymer
Do you have shares in a company that makes MS Polymer adhesives Jake
No it's just f**king ace (apart from some bathroom specific crap I bought which has gone horribly yellow, at least I could paint it I suppose) and so much better than silicone.
Since I discovered CT1 I haven't used anything else. Brilliant stuff. Sticks to any surface, even if wet, and overpaintable, and doesn't shrink or go brittle with age. Not cheap at around £10 per tube, but well worth it.
Been using Geocel decorators calk which can be used externally as well. Good stuff. Cheap as chips!
Roger-M wrote:Since I discovered CT1 I haven't used anything else. Brilliant stuff. Sticks to any surface, even if wet, and overpaintable, and doesn't shrink or go brittle with age. Not cheap at around £10 per tube, but well worth it.
Unfortunately CT1 yellows.
Toolstation sell the everbuild puraflex 40 for £4.04. TBH I don't know if that yellows or not. Additionally I have only ever seen it in white.
BTW, both products need to be primed with water based paint first, otherwise the oilbased paint will remain tacky for days.
