Peally varnish
Peally varnish
Postby jfc » Fri Aug 07, 2015 9:30 am
The varnish on the deck of my speed boat has started to peal in places . I really don't want to be revarnishing the whole boat so any tips for a fix ?
Re: Peally varnish
Postby tusses » Fri Aug 07, 2015 10:38 am
oil ? will soak in the pealed bits and wipe off the varnished bits
Re: Peally varnish
Postby senior » Fri Aug 07, 2015 11:36 am
tusses wrote:oil ? will soak in the pealed bits and wipe off the varnished bits
Except then you will never be able to revarnish.
Re: Peally varnish
Postby jfc » Fri Aug 07, 2015 6:08 pm
I may try cutting the raised stuff back and then building it up to the same layer . Maybe applying and wiping off until its built up ?
Time consuming but worth a shot ?
sgiandubh
Re: Peally varnish
Postby sgiandubh » Wed Aug 12, 2015 11:29 am
jfc wrote:I may try cutting the raised stuff back and then building it up to the same layer . Maybe applying and wiping off until its built up? Time consuming but worth a shot ?
I'm not sure you have much choice if the existing varnish is peeling. I suspect the only realistic option might be to clean and degrease the surface, and sand back everything until you get to something solid, either bare wood or sound varnish, then apply another coat or three of a good yacht varnish. Where the existing varnish is still sound the cleaning, degreasing and sanding back is only to provide a good key for the new varnish.
From what I've seen, most boat/ yacht owners spend almost as much time keeping the 'brightwork' looking good as they do sailing (ha, ha), especially if the boat is moored outside all the time - sun, wind, rain, hail, salt water, etc, is tough on the varnish. Slainte.
http://www.richardjonesfurniture.com
Re: Peally varnish
Postby senior » Wed Aug 12, 2015 12:11 pm
Are you sure it's not you breath taking it off, I've heard it's pretty corrosive?
sgiandubh
Re: Peally varnish
Postby sgiandubh » Wed Aug 12, 2015 12:17 pm
senior wrote:Are you sure it's not you breath taking it off, I've heard it's pretty corrosive?
No, not from here, I'm pretty certain of that. His boat has to be at least 250 miles away from where I exhale my stinky breathe.
Oh ... er ... perhaps you weren't asking me? Slainte.
