Peally varnish
Peally varnish
The varnish on the deck of my speed boat has started to peal in places . I really don't want to be revarnishing the whole boat so any tips for a fix ?
Re: Peally varnish
oil ? will soak in the pealed bits and wipe off the varnished bits
Re: Peally varnish
tusses wrote:oil ? will soak in the pealed bits and wipe off the varnished bits
Except then you will never be able to revarnish.
Re: Peally varnish
I may try cutting the raised stuff back and then building it up to the same layer . Maybe applying and wiping off until its built up ?
Time consuming but worth a shot ?
Re: Peally varnish
jfc wrote:I may try cutting the raised stuff back and then building it up to the same layer . Maybe applying and wiping off until its built up? Time consuming but worth a shot ?
I'm not sure you have much choice if the existing varnish is peeling. I suspect the only realistic option might be to clean and degrease the surface, and sand back everything until you get to something solid, either bare wood or sound varnish, then apply another coat or three of a good yacht varnish. Where the existing varnish is still sound the cleaning, degreasing and sanding back is only to provide a good key for the new varnish.
From what I've seen, most boat/ yacht owners spend almost as much time keeping the 'brightwork' looking good as they do sailing (ha, ha), especially if the boat is moored outside all the time - sun, wind, rain, hail, salt water, etc, is tough on the varnish. Slainte.
http://www.richardjonesfurniture.com
Re: Peally varnish
Are you sure it's not you breath taking it off, I've heard it's pretty corrosive?
Re: Peally varnish
senior wrote:Are you sure it's not you breath taking it off, I've heard it's pretty corrosive?
No, not from here, I'm pretty certain of that. His boat has to be at least 250 miles away from where I exhale my stinky breathe.
Oh ... er ... perhaps you weren't asking me? Slainte.
