Just replacing the wood on the gable of my place as it was falling off ( for 18 years ) Ive used oak and i'm in two minds about what finish to use .
I live on the main road so the rest of the woodwork will probably be painted black .
Any opinions ?
Oil or paint it ?
Re: Oil or paint it ?
Combine the two & go for linseed oil paint
Might do that as i have to brush it on and i'm scraping the other timber back to bare wood . I think i'll leave the oak uprights clear linseed though .
What was that linseed paint called ?
I wouldn't oil the Oak Jase.Once it goes slivery grey it won't look nice against the pebbledashed panels. I would go for solvent based Architectural Solignum . They do alsorts of colours and ebony (black would look fine) and it doesn't crack or peel.
I've oiled it now
It does look smart , i just need to keep on top of that but given the van with ladders is parked right under it and it just takes a wipe to add more oil ...... Its not going to happen is it
It used to be called Holkham Hall paint, but seems to have undergone an image change http://www.preciousearth.co.uk/shop/vie ... ?groupid=0
£35 for a tin of white paint
Some pics
very nice mate, except for the painting of the casements - could you only find a yard broom to do it with
Also jumped up on the roof to check the pointing and the whole hip was loose
Your oak looks alot nicer up there than it would as doors don't you think
do you have your own scaffold then ?
something I've been thinking about .. I have a 1 floor platform
Borrowed from a mate and now i'm probably going to have to store it but that's fine by me . I wouldn't have done the work if i had to pay for the scaffold . Cheapest quote i had was £600 and that was with two houses on the road having it done at the same time and only one lift .
With this i could just swap it around and get to where i wanted . Time to replace the side shed while i still have it !
I still think what would be wrong with 2x4's " lol
At least I have 1 floor lift .. 2x4's for the rest would be ok ? ! lol
If the Chinese can use bamboo then I don't see why you can't use 4 x 2's. In fact I've used timber to make scaffolding when replacing a roof on a house in Congo when I was working out there.
jfc wrote:...Your oak looks alot nicer up there than it would as doors don't you think
got your spindle fixed yet by any chance?
No , the f**ker sold it for £165 a day before the auction ended
Now after another one thats a pile of sh*t for £400
