lacquer spray finishes
Mike Dempsey
Postby Mike Dempsey » Mon Dec 07, 2015 1:40 pm
I have been using isf clear coat lacquer for a while now and find it an excellent product. However I am forever changing between base coat and top coat wiyth all the cleaning that changing over takes. To cut down the time I am looking to se if there is a base coat and top coat that is the same so, apart from cellulose sanding sealer, I can just keep spraying away and just top up the spraygun cup as it needs it. BTW I am spraying wooden coasters by the hundreds.
Mike
Re: lacquer spray finishes
Postby tusses » Mon Dec 07, 2015 3:02 pm
2 spray guns ?
Mike Dempsey
Postby Mike Dempsey » Mon Dec 07, 2015 6:42 pm
Hadnt thought of that one but it still means the same amount of cleaning to do!
Postby tusses » Mon Dec 07, 2015 8:16 pm
try it ! you'll be surprised at how much time it saves .. then just clean up at the end of the day
Postby tusses » Mon Dec 07, 2015 8:17 pm
or actually .. get a "soak bucket" over night and a quick clean when you need them next :-)
Postby mark270981 » Thu Dec 10, 2015 7:32 pm
Would the 3M PPS system be sufficient.
