Osmo oil 420
MRS CHISEL
Osmo oil 420
Postby MRS CHISEL » Mon Dec 28, 2015 6:52 pm
Has anyone used Osmo oil? I put a coat on some oak a couple of days ago and it is still tacky.
Is this normal? Feels 'orrible at the moment!
Re: Osmo oil 420
Postby promhandicam » Mon Dec 28, 2015 9:10 pm
Is this something inside or outside? If outside it may take a while in this weather. Note that you need to apply any oil very thinly and after 10 minutes wipe any excess off. If it is still tacky then use some white spirit to clean it of and start again.
MRS CHISEL
Re: Osmo oil 420
Postby MRS CHISEL » Thu Dec 31, 2015 2:21 pm
Thanks, will try again!
ja2_k
Re: Osmo oil 420
Postby ja2_k » Fri Jan 01, 2016 8:55 pm
I've had exactly the same problem.I think I'll have to sand back to "no tacky part"
I think its the cold damp weather
Re: Osmo oil 420
Postby Roger-M » Sat Jan 02, 2016 2:18 pm
promhandicam wrote: If it is still tacky then use some white spirit to clean it of and start again.
+1. I've had this happen as well. Either the temperature is too low, or the coat too thick, or the oil was not stirred sufficiently thoroughly. Wipe off with white spirit and allow to dry. Stir oil in can thoroughly. Recoat very thinly using a lint free cloth.
Louis1984
Re: Osmo oil 420
Postby Louis1984 » Fri Feb 12, 2016 9:28 pm
Yes this happens when its too cold and is a nightmare! I once had a heater pointed at a door. It eventually dried but once I turned the heater off it went back to being sticky!
