A tale of 2 knobs
A tale of 2 knobs
Postby Doug » Sun Apr 22, 2012 7:33 pm
Or...it`s done Jonlar
Jon had asked for a knob the combined shape of 2 knobs.
The base to look like the lower half of the bottom black knob & the top to be like the upper half of the top black knob.
Hope it`s OK cause stella`s just arrived so that`s my turning finished for today, :roll:
PM me your address mate as I can`t find it.
Re: A tale of 2 knobs
Postby promhandicam » Sun Apr 22, 2012 10:03 pm
It might be my monitor or your photography but the colour doesn't seem to be a very good match. :lol:
Postby Doug » Sun Apr 22, 2012 10:14 pm
promhandicam wrote:It might be my monitor or your photography but the colour doesn't seem to be a very good match. :lol:
Jon assured me he had some boot polish :?
Postby mrgrimsdale » Sun Apr 22, 2012 10:20 pm
How do you attach them! I've been doing them with 5/8" spigots which make them easy to attach to the drawer but are a bugger to get exactly right diameter. Is there a trick? Can't be bothered with wood taps and dies.
Postby Doug » Sun Apr 22, 2012 10:25 pm
mrgrimsdale wrote:How do you attach them! I've been doing them with 5/8" spigots which make them easy to attach to the drawer but are a bugger to get exactly right diameter. Is there a trick? Can't be bothered with wood taps and dies.
The black knobs Jon supplied had a pilot hole drilled in them, so where designed to be screwed through the draw box.
Previously I made them will a 10mm spigot which i used calipers to gauge the size with.
Postby mrgrimsdale » Sun Apr 22, 2012 10:31 pm
Doug wrote:.....
I do that but it seems quite slow to get an accurate diameter. There must be a quick way where you just bang in a chisel and get it right every time, as the finish doesn't really matter. I guess I need more practice!
Postby mrgrimsdale » Sun Apr 22, 2012 10:38 pm
Come to think, turning could be the thing, following my latest ebay bargain! Am working out what I can do sitting down in the workshop. Eating pies, doing crosswords, no prob so far.
http://www.ebay.co.uk/itm/110858981723? ... 500wt_1029
Daughter had a go on it and whacked it into a wall straightaway. Luckily at very low speed. I had a go and got the throttle jammed and it went to and fro from wall to wall like a dodgem until I thought to switch it off.
andrewking
Postby andrewking » Sun Apr 22, 2012 10:49 pm
mrgrimsdale wrote:
Doug wrote:.....
The old favourite is with an open ended spanner of the size you need.
Grind one side down to a cutting edge so that once its pushed against the work it stops cutting once the size is achieved, the spanner dropping over the newely turned spigot.
Andy
haha! might help to read other threads - its been posted further down in the 'sizing tool' one! :lol:
Postby mrgrimsdale » Mon Apr 23, 2012 8:52 am
andrewking wrote:
mrgrimsdale wrote:
Doug wrote:.....
Andy
Right. I have used a spanner as a caliper - they are handy as they come in all sizes and they stay set even if you drop them.
But hadn't thought of sharpening one side. Sounds a really good idea and I'll have a go as soon as possible!
Postby jonnyd » Mon Apr 23, 2012 10:08 pm
Only just seen this looks great Doug. Are you ready to make 40 in ebony if the design is approved :D
Will pm details
Return to “Turning”
