This went onto what was her old external wall in a new extension so their was an existing window to frame around in the middle of the dresser unit and 1 to the left. Not the best pictures. I should of put a camera on my crimbo list.
Happy new year.
Dresser
Re: Dresser
That looks fantastic.
Re: Dresser
Thanks.
Re: Dresser
It's amazing how effective a simple design can look when finished. the wood on the top of the unit and bead mould on the side and back panels look really good. Can I ask what type size of joint you used on the door frames?
Re: Dresser
Nice job
Re: Dresser
Meccarroll wrote:It's amazing how effective a simple design can look when finished. the wood on the top of the unit and bead mould on the side and back panels look really good. Can I ask what type size of joint you used on the door frames?
framework is all dominoes and screws, doors have 9 mm panels so 9mm m & t but with an 8x50 domino aswell on the 2 larger ones.
Thanks for all the nice comments.
Re: Dresser
Tomyjoiner wrote:Meccarroll wrote:It's amazing how effective a simple design can look when finished. the wood on the top of the unit and bead mould on the side and back panels look really good. Can I ask what type size of joint you used on the door frames?
Thank you for sharing your construction design. Dominoes seem to be very much in fashion today, any reason for choosing them over biscuit joints ? or is it just either either?
Re: Dresser
when my buiscuiter packed in a treat myself to a domino'er. Never looked back,They have a greater glue area aswell.
Re: Dresser
Once you go domino you never look back excellent work.
chippy1970
Re: Dresser
Nice job looks good
