Coffee table
Belmont Bespoke
Coffee table
Postby Belmont Bespoke » Sat Jan 09, 2016 10:07 am
Hi guys,
I'd appreciate any feedback on a little coffee table I've just built,
I've added a couple of pics.
Basically I can't decide now I've built it if I like it or not! Something just doesn't seem quite right to my eye, maybe the legs? I'm thinking of making some wooden legs instead now.
The table is constructed from 2 planks of solid Iroko 50mm thick, finished in Osmo oil and has steel hairpin legs.
Thanks!
Mike
www.belmontbespoke.com
simuk
Re: Coffee table
Postby simuk » Sat Jan 09, 2016 11:06 am
I am not sure if I like it either :) Is it because the top and the legs are are contradicting each other? The top has straight lines but the bottom of the legs are curved, also the top is chunky opposed to the legs which are thin. Maybe round off the corners off the top :lol:
It reminds of when I went to the national gallery in London and looked at van gogh sunflowers, I couldn't make my mind up if I liked that either.
Re: Coffee table
Postby tusses » Sat Jan 09, 2016 11:10 am
I'd say the top is to thick for the legs , for my taste.
Maybe taper the bottom edges to make it appear thinner ?
I like the over all design though :-)
Belmont Bespoke
Re: Coffee table
Postby Belmont Bespoke » Sat Jan 09, 2016 3:00 pm
Thanks for you're input,
Yes! Exactly what I was thinking, the top is too heavy and too square to go with these legs!
My plan will be now to make some matching iroko chunkier legs and use these hairpin legs on another project!
In my head this was going to work perfectly! Oh well you live and learn constantly in woodworking ;)
Mike
Re: Coffee table
Postby davidpidge » Sun Jan 10, 2016 6:22 pm
It would probably help if the legs moved out to the corners if that's possible.
Re: Coffee table
Postby mark270981 » Sun Jan 10, 2016 7:35 pm
Imo top is too thick for legs as mentioned above, but I like the idea of the legs btw
Re: Coffee table
Postby promhandicam » Sun Jan 10, 2016 8:21 pm
davidpidge wrote:It would probably help if the legs moved out to the corners if that's possible.
That was my first thought as well. As others have said, the top does look, and obviously is, heavy. Maybe chamfer the underside to give the impression that it is thinner.
Belmont Bespoke
Re: Coffee table
Postby Belmont Bespoke » Sun Jan 10, 2016 10:11 pm
Right attached are some modifications I have done today, I've taken the steel hairpin legs off and donated them to another table top I have been working on, which I'm really happy with , this one's from reclaimed mahogany pier decking boards (from the old west pier in Brighton that burnt down)
And then I've made up some more modern looking iroko matching legs for the original table.
I'm really happy with the results now as I think the legs match a lot nicer to their respective tables :)
Mike
rhrwilliams
Re: Coffee table
Postby rhrwilliams » Wed Jan 20, 2016 6:55 pm
I like the metal legs I think they look really smart.
