Learning Curve
Learning Curve
Just thought i would show you the current kitchen i am working on.As part of the island section there
is a curved barrel shaped unit somthing i have never done before. Just thought i would show you how
i have done it. Thanks for looking.
New kitchen design
Laminating curved base rail in 2mm tulip wood
Side sections done in bendi mdf with a 4mm tulip veneer on the face
Doweled and ready to glue
Glueing up, used Tregarne wood welder to set glue
Made cutters for curved door sections
Used template to rout 12mm groove for panels
Shown with groove in
Styles grooved and doweled
Mid rail and chopping board holes chopped out
Curved skirting added
Doors made and ready to fit
Side profile
New kitchen design
Side profile
www.paulbarrow-kitchens.co.uk
Re: Learning Curve
Nice work Paul
Thanks for sharing
Thanks for sharing
Re: Learning Curve
Where did you get that router bearing thingy from ?
Re: Learning Curve
jfc wrote:Where did you get that router bearing thingy from ?
It came with the router when i bought it
telos
Re: Learning Curve
I remember seeing something like that at a woodworking show. Never seen it for sale anywhere though.
Have a look at this page and scroll down to the little pictures. This German company seems to make something very similar.
Probably bleedin' expensive though, as their flexi curve stuff is made out of only the most expensive unobtainium.
Re: Learning Curve
Thanks for sharing the info, always pick up bits and pieces this way and makes life easier in the future.
Re: Learning Curve
I've got one of those for the OF1010.
The kitchen looks great for that style.
Not to pick holes, but the garden looks a bit monotonous.
Re: Learning Curve
Looks great. how did you make the curved skirting?
Re: Learning Curve
mailee wrote:Looks great. how did you make the curved skirting?
I used the cabinet as the template, glued 3 pieces of 6mm bendi mdf then 3x 2mm
tulip wood. then made a top section of 40mm x 25mm made up of tulip laminate and glued
it to the top so i had solid wood to rout the profile on.
thanks
Re: Learning Curve
Looks really good mate.
It's good to see someone else shaping the stiles. Flat stiles ruin the look of a curved door, in my opinion.
Why did you dowel the joints, as opposed to tenoning them? All you need is a jig for the spindle (outside rad of rails) to cradle the rail as it passes the cutter(s)?
Adam.
Adam.
http://www.rileytoolworks.co.uk
Re: Learning Curve
riley wrote:Looks really good mate.
It's good to see someone else shaping the stiles. Flat stile ruin the look of a curved door, in my opinion.
Why did you dowel the joints, as opposed to tenoning them? All you need is a jig for the spindle (outside rad of rails) to cradle the ail as it passes the cutter(s)?
Adam.
Thanks Adam
Its so much easier to dowel and just as strong,.
Re: Learning Curve
Thanks for sharing this Paul very interesting. How do you cope with springback in the laminations? epoxy or tighter template?
Re: Learning Curve
Cheers Jon
No springback at all, as I use cascamite, great stuff
Re: Learning Curve
Looks fantastic Paul,
how many layers of the 2mm did it take for the door rails?
Re: Learning Curve
Nice work Paul. I'll have to pop in and say hello some time, i'm only in Leeds.
Re: Learning Curve
mattty wrote:Nice work Paul. I'll have to pop in and say hello some time, i'm only in Leeds.
Thanks Matt
We have met before in a round about way
I am from Rothwell originally. Your quite welcome
To nip in for a pot of tea anytime
Re: Learning Curve
simuk wrote:Looks fantastic Paul,
It took 14 per rail
urbanarcher
Re: Learning Curve
Hi Paul could i ask whet software your using to produce your 3d representations? Great work btw lovely curved unit Thanks for sharing.
Ryan
Ryan
Re: Learning Curve
Cool rendering.
Thanks for sharing, I gleaned a lot from your methods.
Re: Learning Curve
urbanarcher wrote:Hi Paul could i ask whet software your using to produce your 3d representations? Great work btw lovely curved unit Thanks for sharing.
Ryan
Thanks very much for your comments Ryan
The software that I use is Articad, been using it
About 8 years now great bit of kit, it did cost £4,500
But it does get me a lot of work. The kitchen you are looking
At is for a new build so its great for the customer to see
Re: Learning Curve
alex wrote:Cool rendering.
Cheers Alex
I like a bit of a challenge, took me longer than
I thought
Re: Learning Curve
Found it, thanks Paul. Quality work, thanks for sharing.
Re: Learning Curve
Hi Paul,
I know this topic is a bit old but i am currently looking at a kitchen with a similar curved barrel at the end of an island but i cannot figure out how to show this in articad. Could you explain how you did this in articad.
Thanks for the help. Hopefully!
Kevin
Kevin
Re: Learning Curve
Nice work Paul.
Re: Learning Curve
Thanks for reposting the link to this Paul. Missed this the first time around. Lovely stuff - I shall file that for future use.
Re: Learning Curve
No probs Roger, seems funny looking back that was in my old workshop
Re: Learning Curve
Paul,
Beautifull work !!
looked like a interesting job.
You should be very proud.
Beautifull work !!
Re: Learning Curve
Paul, I also missed this the first time around. Your workmanship keeps on shining through. Thank you for taking the time to post.
Neil
Neil
Re: Learning Curve
Cheers everyone here is a picture I found with the top on it, and chopping boards in, and primed
Finished kitchen for those that haven't seen it
